Good morning I can’t install the GeForce 730 drivers on linux mint, I tried to install from driver manager both the recommended proprietary 340 driver and the 390 but on reboot before login the screen stays black with a dash and dot in the upper left corner and freezes. I tried to install the nvidia .run file but the terminal tells me it is not supported. Can you help me install the drivers?
The 470 series of drivers should have support for the GT 730 as well
Maybe try these?
Please post the output of
sudo lspci -nn -d 10de:*
to check which driver is needed.
This is the output
visenci@duvisenci:~$ sudo lspci -nn -d 10de:*
[sudo] password di visenci:
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GF108 [GeForce GT 730] [10de:0f02] (rev a1)
01:00.1 Audio device [0403]: NVIDIA Corporation GF108 High Definition Audio Controller [10de:0bea] (rev a1)
It’s a Fermi based gpu so the 390 driver has to be used. Please install it using the driver manager, then run nvidia-bug-report.sh as root and attach the resulting nvidia-bug-report.log.gz file to your post.
I tried but the terminal gives me the output that it is not supported.
Don’t use the runfile installer of legacy drivers, those won’t compile on recent kernels.
He says it is nonexistent.
nvidia-bug-report.sh will now collect information about your
system and create the file ‘nvidia-bug-report.log.gz’ in the current
directory. It may take several seconds to run. In some
cases, it may hang trying to capture data generated dynamically
by the Linux kernel and/or the NVIDIA kernel module. While
the bug report log file will be incomplete if this happens, it
may still contain enough data to diagnose your problem.
Please include the ‘nvidia-bug-report.log.gz’ log file when reporting
your bug via the NVIDIA Linux forum (see devtalk.nvidia.com)
or by sending email to ‘linux-bugs@nvidia.com’.
Running nvidia-bug-report.sh…ls: impossibile accedere a ‘/proc/driver/nvidia/./gpus/’: File o directory non esistente
If the bug report script hangs after this point consider running with
–safe-mode and --extra-system-data command line arguments.
complete.
Please attach the resulting nvidia-bug-report.log.gz
nvidia-bug-report.log.gz (93.4 KB)
NVRM: RmInitAdapter failed! (0x26:0xffff:1123)
I guess the gpu might be broken.
I think it is impossible that it is broken. In the pc I have an integrated video card that does not work and the geforce video card.I have the pc in dual boot with windows and on windows it works properly
I’m having the same issue on nixos
08:00.0 VGA compatible controller [0300]: NVIDIA Corporation GF108 [GeForce GT 730] [10de:0f02] (rev a1)
08:00.1 Audio device [0403]: NVIDIA Corporation GF108 High Definition Audio Controller [10de:0bea] (rev a1)
someone please show a fix
I’m broke. I wanna use this GPU with the legacy driver on linux
T-T
What kernel are you on ? most distro’s requires to downgrade to kernel 5.15 in order to install the legacy 390.xx driver.
can I downgrade my kernel and then use that driver?
That’s true.
There’s another solution : if all this did not work, simply get back to older 5.15.0.xxx kernels and install ubuntu 22.04 LTS again. This Nvidia card, isn’t supported anymore and Nvidia don’t provide drivers anymore except the 390.xxx old driver. In Linux, there are Nouveau2 drivers, but you won’t have needed accelerations, and you won’t be able to play games without “lag” and “tearing”. After doing this (and supress newer kernels), you will be able to use Nvidia private driver again with all acceleration, with the program Nvidia-settings enabled. Once you installed the old 5.15.0.134 kernel again (not 6.x.xxx series), you have to go to “other drivers”, and choose the private Nvidia driver for Nvidia geforce gt 730, with 390.xxx package. You click on it, wait for the install to complete, and you will see the nvidia-settings icon appear in “activities”, and you are all set.
Mine works on linux mint 22 wilma:
uname -a
Linux ******* 6.8.0-51-generic #52-Ubuntu SMP PREEMPT_DYNAMIC Thu Dec 5 13:09:44 UTC 2024 x86_64 x86_64 x86_64 GNU/Linux
lspci -nn -d 10de:*
09:00.0 VGA compatible controller [0300]: NVIDIA Corporation GK208B [GeForce GT 730] [10de:1287] (rev a1)
glxinfo | grep -i version
OpenGL core profile version string: 4.6.0 NVIDIA 470.256.02
My solutions
When booting, select Start Linux Mint (compatibility mode).
After that, choose Recovery with kernel 5.15xx.
Continue by opening the terminal with the option “root drop to root shell prompt”.
Then press Enter, and you will be in terminal mode.
Proceed by running the command:
sudo nano /etc/default/grub
Next, edit the line:
GRUBCMDLINELINUX_DEFAULT=“quiet splash”
to become:
GRUBCMDLINELINUX_DEFAULT=“quiet splash nvidia-drm.modeset=1”
Save it, then update grub
sudo grub-mkconfig -o /boot/grub/grub.cfg
Final reboot the system
sudo reboot
this allowed me to bypass the black screen and actually load into the desktop.
