to maximize gpu performance, but it seems directory paths are different in my TX1.
(facerec-cv3.3-np1.13.1-py2.7) nvidia@tegra-ubuntu:~/softwares$ sudo ./jetson_clocks.sh
cat: /sys/devices/system/cpu/cpuquiet/tegra_cpuquiet/enable: No such file or directory
./jetson_clocks.sh: line 138: /sys/devices/system/cpu/cpuquiet/tegra_cpuquiet/enable: No such file or directory
cat: /sys/kernel/debug/clock/override.gbus/min: No such file or directory
cat: /sys/kernel/debug/clock/override.gbus/max: No such file or directory
cat: /sys/kernel/debug/clock/override.gbus/rate: No such file or directory
cat: /sys/kernel/debug/clock/override.gbus/state: No such file or directory
./jetson_clocks.sh: line 189: /sys/kernel/debug/clock/override.gbus/rate: No such file or directory
./jetson_clocks.sh: line 190: /sys/kernel/debug/clock/override.gbus/state: No such file or directory
Error: Failed to max GPU frequency!
cat: /sys/kernel/debug/clock/override.emc/min: No such file or directory
cat: /sys/kernel/debug/clock/override.emc/max: No such file or directory
cat: /sys/kernel/debug/clock/override.emc/rate: No such file or directory
cat: /sys/kernel/debug/clock/override.emc/state: No such file or directory
./jetson_clocks.sh: line 215: /sys/kernel/debug/clock/override.emc/rate: No such file or directory
./jetson_clocks.sh: line 216: /sys/kernel/debug/clock/override.emc/state: No such file or directory
I found the solution:
I will put the whole script in the near future in https://github.com/smajida
do_gpu()
case “${SOCFAMILY}” in
tegra186)
GPU_MIN_FREQ=“/sys/devices/17000000.gp10b/devfreq/17000000.gp10b/min_freq”
GPU_MAX_FREQ=“/sys/devices/17000000.gp10b/devfreq/17000000.gp10b/max_freq”
GPU_CUR_FREQ=“/sys/devices/17000000.gp10b/devfreq/17000000.gp10b/cur_freq”
GPU_RAIL_GATE=“/sys/devices/17000000.gp10b/railgate_enable”
tegra210)
GPU_MIN_FREQ=“/sys/devices/57000000.gpu/devfreq/57000000.gpu/min_freq”
GPU_MAX_FREQ=“/sys/devices/57000000.gpu/devfreq/57000000.gpu/max_freq”
GPU_CUR_FREQ=“/sys/devices/57000000.gpu/devfreq/57000000.gpu/cur_freq”
GPU_RAIL_GATE=“/sys/devices/57000000.gpu/railgate_enable”
echo “Error! unsupported SOC ${SOCFAMILY}”
exit 1;
esac
case "${ACTION}" in
show)
echo "GPU MinFreq=`cat ${GPU_MIN_FREQ}`" \
"MaxFreq=`cat ${GPU_MAX_FREQ}`" \
"CurrentFreq=`cat ${GPU_CUR_FREQ}`"
store)
store "${GPU_MIN_FREQ}"
store "${GPU_RAIL_GATE}"
echo 0 > "${GPU_RAIL_GATE}"
cat "${GPU_MAX_FREQ}" > "${GPU_MIN_FREQ}"
ret=$?
if [ ${ret} -ne 0 ]; then
echo "Error: Failed to max GPU frequency!"
fi
esac
