How to improve the working frequency of TX1 GPU? Our GPU is currently working frequency is 844M, and we want to increase it to 998M?
thanks
thanks
Hello 2335440898:
What is the BSP version are you using ?
Is it possible you can try below command?
$ sudo nvpmodel -m 0
$ sudo ~/jetson_cloc.sh
hi rock,
nvpmodel and jetson_cloc were not found on the device.According to the code, the final merged version is SDK R 24.2.1.
what’s the SDK version you are using?
can you paste the kernel log?
br
Chenjian
We can provide partial kernel log, The following:
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.10.96+
[ 0.000000] CPU: Cortex A57 Processor [411fd071] revision 1
[ 0.000000] alternative: enabling workaround for ARM erratum 832075
[ 0.000000] Machine: jetson_tx1
[ 0.000000] bootconsole [earlycon0] enabled
[ 0.000000] Malformed early option ‘dbg’
[ 0.000000] Reserved memory: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] Tegra reserved memory:
[ 0.000000] LP0: ff2bf000 - ff2bffff
[ 0.000000] Bootloader framebuffer: 00000000 - 00000000
[ 0.000000] Bootloader framebuffer2: 00000000 - 00000000
[ 0.000000] Framebuffer: 00000000 - 00000000
[ 0.000000] 2nd Framebuffer: 00000000 - 00000000
[ 0.000000] Carveout: 00000000 - 00000000
[ 0.000000] Vpr: 00000000 - 00000000
[ 0.000000] Tsec: 00000000 - 00000000
[ 0.000000] Bootloader Debug Data: 00000000 - 00000000
[ 0.000000] Nvdumper: ff23f000 - ff23ffff
[ 0.000000] cma: CMA: reserved 16 MiB at fdc00000
[ 0.000000] On node 0 totalpages: 1043968
[ 0.000000] DMA32 zone: 7168 pages used for memmap
[ 0.000000] DMA32 zone: 0 pages reserved
[ 0.000000] DMA32 zone: 519680 pages, LIFO batch:31
[ 0.000000] Normal zone: 7168 pages used for memmap
[ 0.000000] Normal zone: 524288 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv0.2 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] DTS File Name: arch/arm64/boot/dts/tegra210-jetson-tx1-p2597-2180-a02-devkit-24x7.dts
[ 0.000000] DTB Build time: Jan 30 2018 16:55:24
[ 0.000000] Tegra21: Speedo/IDDQ fuse revision 4
[ 0.000000] Tegra21: CPU Speedo ID 8, Soc Speedo ID 0, Gpu Speedo ID 2
[ 0.000000] Tegra21: CPU Process ID 0, Soc Process ID 0, Gpu Process ID 0
[ 0.000000] Tegra21: CPU Speedo value 2008, Soc Speedo value 1893, Gpu Speedo value 2006
[ 0.000000] Tegra21: CPU IDDQ 1888, Soc IDDQ 2076, Gpu IDDQ 2530
[ 0.000000] Tegra Revision: A02 SKU: 0x17 CPU Process: 0 Core Process: 0 Bootrom patch v0xff
[ 0.000000] tegra: PLLP fixed rate: 408000000
[ 0.000000] tegra dvfs: vdd_cpu: nominal 1188mV, offset 708000uV, step 19200uV, scaling enabled
[ 0.000000] tegra dvfs: vdd_core: nominal 1125mV, offset 0uV, step 12500uV, scaling enabled
[ 0.000000] tegra dvfs: vdd_gpu: nominal 1120mV, offset 710000uV, step 10000uV, scaling enabled
[ 0.000000] Tegra reset control registration success
[ 0.000000] tegra_powergate_init: DONE
[ 0.000000] PERCPU: Embedded 12 pages/cpu @ffffffc01fed3000 s20352 r8192 d20608 u49152
[ 0.000000] pcpu-alloc: s20352 r8192 d20608 u49152 alloc=12*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1029632
[ 0.000000] Kernel command line: …
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 2030MB 2048MB = 4078MB total
[ 0.000000] Memory: 4071944k/4071944k available, 103928k reserved
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 0.000000] NR_IRQS:704 nr_irqs:704 0
[ 0.000000] the number of interrupt controllers found is 6
[ 0.000000] Architected local timer running at 19.20MHz (phys).
[ 0.000000] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 3579139424256ns
[ 0.000000] Console: colour dummy device 80x25
[ 0.000000] console [tty0] enabled
[ 0.001062] Calibrating delay loop (skipped), value calculated using timer frequency.. lpj=192000
[ 0.001071] pid_max: default: 32768 minimum: 301
[ 0.001162] Security Framework initialized
[ 0.001205] Mount-cache hash table entries: 256
[ 0.054378] Initializing cgroup subsys debug
[ 0.054393] Initializing cgroup subsys freezer
[ 0.054574] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available
[ 0.090247] ftrace: Allocated trace_printk buffers
[ 0.150740] Brought up 4 CPUs
[ 0.150747] SMP: Total of 4 processors activated.
[ 0.150767] alternatives: patching kernel code
[ 0.152732] devtmpfs: initialized
[ 0.161070] pinctrl core: initialized pinctrl subsystem
[ 0.161289] regulator-dummy: ; Rail ON
[ 0.161618] Initializing plugin-manager
[ 0.162020] chosen/plugin-manager does’nt have ids and odm-data
[ 0.162027] Error in parsing node /plugin-manager/fragment-e3326@0: -22
[ 0.162142] chosen/plugin-manager does’nt have ids and odm-data
[ 0.162148] Error in parsing node /plugin-manager/fragment-e3323@0: -22
[ 0.162266] chosen/plugin-manager does’nt have ids and odm-data
[ 0.162271] Error in parsing node /plugin-manager/fragment-e3322@0: -22
[ 0.162390] chosen/plugin-manager does’nt have ids and odm-data
[ 0.162394] Error in parsing node /plugin-manager/fragment-e3333@0: -22
[ 0.162501] chosen/plugin-manager does’nt have ids and odm-data
[ 0.162506] Error in parsing node /plugin-manager/fragement@0: -22
[ 0.162615] chosen/plugin-manager does’nt have ids and odm-data
[ 0.162620] Error in parsing node /plugin-manager/fragement@1: -22
[ 0.162727] chosen/plugin-manager does’nt have ids and odm-data
[ 0.162732] Error in parsing node /plugin-manager/fragement@2: -22
[ 0.162839] chosen/plugin-manager does’nt have ids and odm-data
[ 0.162844] Error in parsing node /plugin-manager/fragement@3: -22
[ 0.163084] NET: Registered protocol family 16
[ 0.164872] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.165266] console [pstore-1] enabled
[ 0.165279] ramoops: attached 0x200000@0xff03f000, ecc: 0/0
[ 0.165528] I2C first dynamic bus number based on alias = 7
[ 0.165567] cpuidle: using governor ladder
[ 0.165574] cpuidle: using governor menu
[ 0.166397] PMC: Setting PMIC interrupt active-low
[ 0.167047] tegra-pmc device create success
[ 0.167099] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.167105] Clear bootloader IO dpd settings
[ 0.167113] PMC: configuring io pad defaults
[ 0.167300] PMC: IO pad audio voltage is 1800000
[ 0.167408] PMC: IO pad cam voltage is 1800000
[ 0.167515] PMC: IO pad dbg voltage is 1800000
[ 0.167622] PMC: IO pad dmic voltage is 1800000
[ 0.167729] PMC: IO pad pex-ctrl voltage is 1800000
[ 0.167836] PMC: IO pad spi voltage is 1800000
[ 0.167943] PMC: IO pad uart voltage is 1800000
[ 0.168051] PMC: IO pad bb voltage is 1800000
[ 0.168158] PMC: IO pad audio-hv voltage is 3300000
[ 0.168265] PMC: IO pad spi-hv voltage is 1800000
[ 0.168372] PMC: IO pad gpio voltage is 3300000
[ 0.168479] PMC: IO pad sdmmc3 voltage is 1800000
[ 0.168493] PMC: IO pad pex-bias power is disable
[ 0.168507] PMC: IO pad pex-clk1 power is disable
[ 0.168520] PMC: IO pad pex-clk2 power is disable
[ 0.168525] T210 pmc padctrl driver initialized
[ 0.168563] T210 pmc config for bootrom command passed
[ 0.169260] INFO: pinmux CLAMP_INPUTS_WHEN_TRISTATED: disabled
[ 0.171034] clk_init_from_dt_table: clocks are set from t210-clk-init-table:clkinit-0
[ 0.173083] platform tegra-carveouts.23: SMMU isn’t ready yet
[ 0.173578] platform tegra-carveouts.23: domain=ffffffc0ff20f658 allocates as[0]=ffffffc0ff2040a8
[ 0.173615] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.174208] bpmp: connect returned 0
[ 0.639871] tun: Universal TUN/TAP device driver, 1.6
[ 0.639877] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 0.641271] tegra_xusb_read_usb_calib: usb_calib0 = 0x07a27c10
[ 0.642521] tegra-xhci tegra-xhci: XUSB device id = 0xfac (T210)
[ 0.643061] tegra-xhci tegra-xhci: Firmware File: tegra21x_xusb_firmware (124416 Bytes)
[ 0.643251] tegra-xhci tegra-xhci: Firmware DMA Memory: dma 0x0000000080040000 mapped 0xffffff8000321000 (124416 Bytes)
[ 0.643260] tegra-xhci tegra-xhci: num_hsic_port 0
[ 0.643682] Nvidia Tegra High-Speed USB Device Controller driver (Apr 30, 2012)
[ 0.644887] tegra-xhci tegra-xhci: Firmware timestamp: 2016-06-16 13:21:43 UTC, Version: 50.16 release, Falcon state 0x20
[ 0.644940] tegra-xhci tegra-xhci: Nvidia xHCI Host Controller
[ 0.645034] tegra-xhci tegra-xhci: new USB bus registered, assigned bus number 1
[ 0.645765] tegra-xhci tegra-xhci: irq 71, io mem 0x70090000
[ 0.645838] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.645847] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.645855] usb usb1: Product: Nvidia xHCI Host Controller
[ 0.645862] usb usb1: Manufacturer: Linux 3.10.96+ tegra-xhci
[ 0.645869] usb usb1: SerialNumber: tegra-xhci
[ 0.646097] xHCI xhci_add_endpoint called for root hub
[ 0.646104] xHCI xhci_check_bandwidth called for root hub
[ 0.646187] hub 1-0:1.0: USB hub found
[ 0.646208] hub 1-0:1.0: 5 ports detected
[ 0.714871] tegra-xhci tegra-xhci: Nvidia xHCI Host Controller
[ 0.714895] tegra-xhci tegra-xhci: new USB bus registered, assigned bus number 2
[ 0.714972] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 0.714980] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.714988] usb usb2: Product: Nvidia xHCI Host Controller
[ 0.714995] usb usb2: Manufacturer: Linux 3.10.96+ tegra-xhci
[ 0.715002] usb usb2: SerialNumber: tegra-xhci
[ 0.715197] xHCI xhci_add_endpoint called for root hub
[ 0.715203] xHCI xhci_check_bandwidth called for root hub
[ 0.715280] hub 2-0:1.0: USB hub found
[ 0.715298] hub 2-0:1.0: 4 ports detected
[ 0.797307] tegra-i2c 7000c400.i2c: no acknowledge from address 0x42
[ 0.797370] ina3221x 1-0042: ina3221 reset failure status: 0xffffff87
[ 0.797504] ina3221x: probe of 1-0042 failed with error -121
[ 0.797805] tegra-i2c 7000c400.i2c: no acknowledge from address 0x43
[ 0.797863] ina3221x 1-0043: ina3221 reset failure status: 0xffffff87
[ 0.797979] ina3221x: probe of 1-0043 failed with error -121
[ 0.798198] max77620-power-off max77620-power-off.4: Event recorder REG_NVERC : 0x0
[ 0.799257] tegra_aotag tegra-aotag.30: AOTAG probe started
[ 0.799313] tegra_aotag tegra-aotag.30: nominal ft – 105
[ 0.799321] tegra_aotag tegra-aotag.30: tall – 76
[ 0.799327] tegra_aotag tegra-aotag.30: tiddq – 1
[ 0.799334] tegra_aotag tegra-aotag.30: ten-count – 16
[ 0.799340] tegra_aotag tegra-aotag.30: tsample – 9
[ 0.799346] tegra_aotag tegra-aotag.30: pdiv – 8
[ 0.799353] tegra_aotag tegra-aotag.30: nominal cp – 25
[ 0.799359] tegra_aotag tegra-aotag.30: pdiv-ate – 8
[ 0.799365] tegra_aotag tegra-aotag.30: tsamp-ate – 39
[ 0.799371] tegra_aotag tegra-aotag.30: compensation A,B – 10632,-67490
[ 0.799379] tegra_aotag tegra-aotag.30: sensor found :ID 0, Name: aotag0
[ 0.799385] tegra_aotag tegra-aotag.30: reading fuse value for sensor 0
[ 0.799393] tegra_aotag tegra-aotag.30: base-cp:239 shifted-cp:2
[ 0.799400] tegra_aotag tegra-aotag.30: base-ft:4db shifted-ft:ffffffff
[ 0.799406] tegra_aotag tegra-aotag.30: actual_aotag_cp 260, ft 1045
[ 0.799414] tegra_aotag tegra-aotag.30: - Tsens calib value - 0x3a55c92
[ 0.799421] tegra_aotag tegra-aotag.30: CPmask 1fff FTmask 3ffe000
[ 0.799427] tegra_aotag tegra-aotag.30: Tsense calib CP - 0x1c92
[ 0.799434] tegra_aotag tegra-aotag.30: Tsense Actual CP d.35538
[ 0.799440] tegra_aotag tegra-aotag.30: Tsense calib FT - 0x1d2a
[ 0.799446] tegra_aotag tegra-aotag.30: Tsense Actual FT d.39050
[ 0.799453] tegra_aotag tegra-aotag.30: delta ts 3512, temp 785
[ 0.799460] tegra_aotag tegra-aotag.30: thermA-843, thermB–823
[ 0.799466] tegra_aotag tegra-aotag.30: Registering sensor 0
[ 0.799500] tegra_aotag tegra-aotag.30: Bound to TZ : ID 0
[ 0.799509] tegra_aotag tegra-aotag.30: shutdown temperature - 110
[ 0.799517] tegra_aotag tegra-aotag.30: AOTAG EN 60
[ 0.799524] tegra_aotag tegra-aotag.30: Probe done [SUCCESS]:0
[ 0.799619] md: raid0 personality registered for level 0
[ 0.799663] device-mapper: uevent: version 1.0.3
[ 0.799785] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[ 0.800059] Tegra210 cpuidle driver
[ 0.800736] sdhci: Secure Digital Host Controller Interface driver
[ 0.800742] sdhci: Copyright(c) Pierre Ossman
[ 0.800746] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.801011] mmc0: sdhci_tegra_probe line=5737 runtime pm type=mmc rtpm coupled with clock gate, disable-clock-gate=0
[ 0.801030] sdhci-tegra sdhci-tegra.3: Parent select= pll_p rate=408000000
[ 0.801044] sdhci-tegra sdhci-tegra.3: Parent select= pll_c4_out2 rate=199680000
[ 0.801050] Could not add sdhci-tegra.3 to power domain using device tree
[ 0.801640] sdhci-tegra sdhci-tegra.3: Speedo value 1893
[ 0.801652] sdhci-tegra sdhci-tegra.3: Tuning constraints: nom_mv 1125, boot_mv 1125, min_or_mv 1100
[ 0.801742] regulator_get() failed for (sdhci-tegra.3,vqmmc), -19
[ 0.801747] mmc0: no vqmmc regulator found
[ 0.801757] regulator_get() failed for (sdhci-tegra.3,vmmc), -19
[ 0.801762] mmc0: no vmmc regulator found
[ 0.834877] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA
[ 0.835100] mmc1: sdhci_tegra_probe line=5737 runtime pm type=mmc rtpm coupled with clock gate, disable-clock-gate=0
[ 0.835117] sdhci-tegra sdhci-tegra.1: Parent select= pll_p rate=408000000
[ 0.835122] Could not add sdhci-tegra.1 to power domain using device tree
[ 0.836781] sdhci-tegra sdhci-tegra.1: Speedo value 1893
[ 0.836791] sdhci-tegra sdhci-tegra.1: Tuning constraints: nom_mv 1125, boot_mv 1125, min_or_mv 1100
[ 0.839311] regulator_get() failed for (sdhci-tegra.1,vqmmc), -19
[ 0.839318] mmc1: no vqmmc regulator found
[ 0.839327] regulator_get() failed for (sdhci-tegra.1,vmmc), -19
[ 0.839332] mmc1: no vmmc regulator found
[ 0.874899] mmc1: SDHCI controller on sdhci-tegra.1 [sdhci-tegra.1] using ADMA
[ 0.875786] mmc2: sdhci_tegra_probe line=5737 runtime pm type=mmc rtpm coupled with clock gate, disable-clock-gate=0
[ 0.875808] sdhci-tegra sdhci-tegra.0: Parent select= pll_p rate=408000000
[ 0.875846] Could not add sdhci-tegra.0 to power domain using device tree
[ 0.876416] sdhci-tegra sdhci-tegra.0: Speedo value 1893
[ 0.876427] sdhci-tegra sdhci-tegra.0: Tuning constraints: nom_mv 1125, boot_mv 1125, min_or_mv 1100
[ 0.876650] regulator_get() failed for (sdhci-tegra.0,vqmmc), -19
[ 0.876655] mmc2: no vqmmc regulator found
[ 0.876666] regulator_get() failed for (sdhci-tegra.0,vmmc), -19
[ 0.876671] mmc2: no vmmc regulator found
[ 0.914898] mmc2: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA
[ 0.915010] gpio wake35 for gpio=201
[ 0.915375] *** tegra_chip_uid 0x5165914d9b140017 ***
[ 0.917471] tegra-se tegra21-se: tegra_se_probe: complete
[ 0.917905] usbcore: registered new interface driver usbhid
[ 0.917911] usbhid: USB HID core driver
[ 0.917923] tegra_bootloader_debug: Created tegra_bootloader directory
[ 0.917938] tegra_bootloader_debug: Created sysfs interface tegra_bootloader_verify_regs in tegra_bootloader directory
[ 0.917949] tegra_bootloader_debug: Created sysfs interface tegra_bootloader_prof in tegra_bootloader directory
[ 0.918218] nvadsp 702ef000.adsp: in probe()…
[ 0.918831] nvadsp 702ef000.adsp: AMC/ARAM initialized.
[ 0.918937] nvadsp 702ef000.adsp: nvadsp_app_module_probe
[ 0.920731] tegra_throttle : init passed
[ 0.921563] pll_x: not ready for dynamic ramp to 921600000
[ 0.921601] pll_x: not ready for dynamic ramp to 921600000
[ 0.922708] soctherm: prog thresholds
[ 0.922716] soctherm: prog thresholds
[ 0.922722] soctherm: tz:2 not found, skip thresh prog
[ 0.922727] soctherm: prog thresholds
[ 0.922740] soctherm: skipping sensor 4 programming
[ 0.922746] soctherm: skipping sensor 5 programming
[ 0.922754] soctherm: trip_point temp 127500 forced to 127000
[ 0.923672] GACT probability NOT on
[ 0.923683] Mirror/redirect action on
[ 0.923690] u32 classifier
[ 0.923695] Actions configured
[ 0.923702] Netfilter messages via NETLINK v0.30.
[ 0.923754] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 0.924003] ctnetlink v0.93: registering with nfnetlink.
[ 0.924092] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 0.924097] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 0.924357] xt_time: kernel timezone is -0000
[ 0.924460] ipip: IPv4 over IPv4 tunneling driver
[ 0.924819] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 0.924977] arp_tables: (C) 2002 David S. Miller
[ 0.925015] TCP: cubic registered
[ 0.925021] Initializing XFRM netlink socket
[ 0.925130] NET: Registered protocol family 10
[ 0.925913] mip6: Mobile IPv6
[ 0.925943] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 0.926080] sit: IPv6 over IPv4 tunneling driver
[ 0.926764] NET: Registered protocol family 17
[ 0.926789] NET: Registered protocol family 15
[ 0.926850] NET: Registered protocol family 35
[ 0.926915] Key type dns_resolver registered
[ 0.926922] NET: Registered protocol family 41
[ 0.928026] Registering SWP/SWPB emulation handler
[ 0.928432] mmc0: BKOPS_EN bit is not set
[ 0.952785] isp isp.0: initialized
[ 0.954036] isp isp.1: initialized
[ 0.954263] vdd_gpu: disabling
[ 0.954273] en-vdd-vcm-2v8: disabling
[ 0.954280] en-usb-vbus2: disabling
[ 0.954286] usb-vbus3: disabling
[ 0.954292] usb-vbus1: disabling
[ 0.954297] vdd-disp-3v0: disabling
[ 0.954305] snsr_pm: disabling
[ 0.954311] aux-3v3: disabling
[ 0.954318] lcd-bl-en: disabling
[ 0.954324] max77620-gpio7: disabling
[ 0.965895] vdd-cpu-fixed: disabling
[ 0.965904] regulator-dummy: disabling
[ 0.966185] reg-fixed-sync-voltage 5.regulator: Consumer c1 does not have device name
[ 0.966266] platform 5.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 0.966493] platform 7.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 0.966660] platform d.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 0.966821] platform c9.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 0.966978] platform ca.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 0.967138] platform cb.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 0.967294] platform cc.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 0.967453] platform cd.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 0.967585] reg-fixed-sync-voltage ce.regulator: Consumer c0 does not have device name
[ 0.967621] platform ce.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 0.967780] platform d1.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 0.967937] platform d3.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 0.968318] unable to find transceiver of type USB2 PHY
[ 0.968325] unable to find transceiver of type USB3 PHY
[ 0.968331] otg_wakelock_init: No USB transceiver found
[ 0.969336] tegra-rtc 7000e000.rtc: setting system clock to 2013-01-01 00:00:00 UTC (1356998400)
[ 0.969492] vi vi: vi_probe: ++
[ 0.971476] vi vi: initialized
[ 0.971836] vi vi: parsing node /host1x/vi
[ 0.971847] vi vi: handling endpoint /host1x/vi/ports/port@0/endpoint
[ 0.971888] vi vi: handling endpoint /host1x/vi/ports/port@1/endpoint
[ 0.971922] vi vi: handling endpoint /host1x/vi/ports/port@2/endpoint
[ 0.971953] vi vi: handling endpoint /host1x/vi/ports/port@3/endpoint
[ 0.971985] vi vi: handling endpoint /host1x/vi/ports/port@4/endpoint
[ 0.972014] vi vi: handling endpoint /host1x/vi/ports/port@5/endpoint
[ 0.972043] vi vi: warning: no subdev found in graph
[ 0.972238] reg-fixed-sync-voltage 5.regulator: Consumer c1 does not have device name
[ 0.972281] platform 5.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 0.972474] platform 7.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 0.972634] platform d.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 0.972793] platform c9.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 0.972949] platform ca.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 0.973106] platform cb.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 0.973260] platform cc.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 0.973420] platform cd.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 0.973553] reg-fixed-sync-voltage ce.regulator: Consumer c0 does not have device name
[ 0.973589] platform ce.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 0.973746] platform d1.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 0.973901] platform d3.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 0.974442] [dram-timers] DRAM derating cdev registered.
[ 0.974458] Disable partitions left on by BL
[ 0.974790] Disabling clocks left on by bootloader:
[ 0.974795] audio2_dmic
[ 0.974802] audio1_dmic
[ 0.974807] audio0_dmic
[ 0.974813] audio_2x
[ 0.974821] audio
[ 0.974826] audio4
[ 0.974832] audio3
[ 0.974837] audio2
[ 0.974843] audio1
[ 0.974867] audio0
[ 0.974926] entropy
[ 0.974937] dsi2-fixed
[ 0.974942] dsi1-fixed
[TCPC][1 4083717096][tlink.c 459]socket connect error! ret -1
[ 0.974963] sdmmc4_ddr
[ 0.974970] sdmmc1_ddr
[ 0.974978] qspi
[ 0.974999] sata_aux
[TCPC][1 4083717407][tlink.c 503]client setup error -19.
[ 0.975007] sor1_src
[ 0.975022] cclk_lp
[ 0.975619] tegra_cl_dvfs 70110000.dfll-ovr: DT data retrieved successfully
[ 0.975852] tegra_cl_dvfs_init_cdev: cpu_cold cooling device registered
[ 0.975911] tegra_cl_dvfs_init_cdev: cpu_hot cooling device registered
[ 0.976013] reg-fixed-sync-voltage 5.regulator: Consumer c1 does not have device name
[ 0.976058] platform 5.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 0.976248] platform 7.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 0.976411] platform d.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 0.976569] platform c9.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 0.976728] platform ca.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 0.976887] platform cb.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 0.977043] platform cc.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 0.977202] platform cd.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 0.977335] reg-fixed-sync-voltage ce.regulator: Consumer c0 does not have device name
[ 0.977372] platform ce.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 0.977531] platform d1.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 0.977688] platform d3.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 0.977933] Tegra CPU DFLL is initialized with use_dfll = 1
[ 0.978051] tegra_dvfs: 0.vdd-cpu-rail-ovr connected to regulator
[ 0.978274] tegra_dvfs: 4.vdd-core-rail-max77620 connected to regulator
[ 0.978398] tegra_dvfs: 1.vdd-gpu-rail-ovr connected to regulator
[ 0.978837] CPU rate: 921 MHz
[ 0.979052] last reset is due to power on reset
[ 0.979052]
[ 0.979059] KERNEL: PMC reset status reg: 0x0
[ 0.979627] tegra_actmon.emc: Completed initialization (0)
[ 0.980038] tegra_actmon.avp: Completed initialization (0)
can you run (with root) following command and paste your result here?
ls -l /sys/devices/57000000.gpu/devfreq/57000000.gpu/
cat /sys/devices/57000000.gpu/devfreq/57000000.gpu/*
In addition, with official earlier release, there’s a script in /home/ubuntu named jetson_clocks.sh. You can run that script with root, and all clocks will be boosted.
br
Chenjian
