hello :
i run the deviceQuery in cuda/samples/
the GPU frequency is 72MHz is it too low for a high-performance device?
hello edwardlu,
could you please run the deviceQuery again and paste the details.
moreover, which JetPack version you were using? thanks
hello edwardlu,
you’re able to upload the attachment by EDIT your comments on the top-right.
FYI, if you hover your mouse over the quote symbol in the upper right several icons show up…the paper clip icon is for attaching files to an existing post.
hello edwardlu,
may i know which JetPack version you were used?
paste the GPU max clock rate with TX1/JetPack 3.0.
thanks
GPU Max Clock rate: 998 MHz (1.00 GHz)
hello jerry:
jetpack 2.4 is this the reason caused the low frequency such as 72M?
hello edwardlu,
please use latest public release JetPack package for development,
thanks
