GPU related information missing when using nsys profile
I met several issues when I run the following script, and in generated report3.qdrep, there is no GPU related information,would you please help to check? Thanks!
nsys profile --stats=true python3 run.py run T5 ‘trt’ --variant ‘t5-small’ --working-dir tem --fp16
###############################error message##############################################################
Collecting data…
/usr/bin/python3: symbol lookup error: /usr/local/lib/python3.10/dist-packages/nsys_cli_pycli_wrapper/nsys_cli_dist/target-linux-x64/libToolsInjectionProxy64.so: undefined symbol: __libc_dlclose, version GLIBC_PRIVATE
The target application returned non-zero exit code 127
Processing events…
Saving temporary “/tmp/nsys-report-17e1-3467-54a2-75ab.qdstrm” file to disk…
Creating final output files…
Processing [===============================================================100%]
Saved report file to “/tmp/nsys-report-17e1-3467-54a2-75ab.qdrep”
Exporting 45 events: [=====================================================100%]
Exported successfully to
/tmp/nsys-report-17e1-3467-54a2-75ab.sqlite
Report file moved to “/mnt/data/flan-t5/TensorRT/demo/HuggingFace/report3.qdrep”
Report file moved to “/mnt/data/flan-t5/TensorRT/demo/HuggingFace/report3.sqlite”
##############################verison information####################################################################
NVIDIA-SMI 530.30.02 Driver Version: 530.30.02 CUDA Version: 12.1
NVIDIA Nsight Systems version 2021.3.2.12-9700a21
Timestamp counter supported: Yes
Sampling Environment Check
Linux Kernel Paranoid Level = -1: OK
Linux Distribution = Ubuntu
Linux Kernel Version = 5.4.0-148-generic: OK
Linux perf_event_open syscall available: OK
Sampling trigger event available: OK
Intel(c) Last Branch Record support: Available
Sampling Environment: OK
@afroger for initial triage.
You’re using years old version of the tool. Could you please try our latest web release? (link)
