安装NVIDIA GPU Direct for Video SDK 安装包,采用fifoCUDA示例程序,调用dvpInitCUDAContext(DVP_DEVICE_FLAGS_SHARE_APP_CONTEXT)函数返回-1,
示例程序的打印信息:
CUDA fifo example v0.3
DVP_ERROR: Initialization failed
Fail on line 877
DVP Failed with status FFFFFFFF
Fail on line 885
WARNING!!! Testing data enabled, so may be slow perf.
Assertion failed: 0, file extsdk.cpp, line 997
here are potential solutions to the issue you’re facing with the NVIDIA GPU Direct for Video SDK and the fifoCUDA sample program, specifically regarding the dvpInitCUDAContext function returning -1:
- Check System Requirements:
- Ensure your system meets all the required hardware and software specifications for the NVIDIA GPU Direct for Video SDK and the fifoCUDA sample program.
- Verify Installation:
- Confirm that the installation of the NVIDIA GPU Direct for Video SDK and the fifoCUDA sample program was completed correctly without any errors.
- Debugging Process:
- Utilize debugging tools to analyze error logs and the application flow, which may help to identify the cause of the issue with the
dvpInitCUDAContextfunction.
- Update Drivers and Software:
- Ensure all GPU drivers and the CUDA Toolkit are up to date. Compatibility issues or bugs in outdated versions could lead to errors.
