Grafana monitors tx2 resources
I want to use grafana and prometheus to monitor the tx2 cpu and gpu. The cpu uses node-exporter and the gpu has two: one is nvidia-gpu-exporter and the other is DCGM. But it seems that the exporter of these two Gpus does not support tx2, is there any other exporter available? Also, does node-exporter support monitoring of tx2 cpus? Thank you for your reply, thank you very much!
We would suggest run sudo tegrastats to check system status. This command can show loading and frequency of most hardware blocks.
