Graphics driver hangs when enabling HDR
Whenever I try to enable HDR, the graphics will completely lock up. My right monitor (Gigabyte G27Q) goes black and my left monitor (Acer 27" Nitro VG271US) just keeps showing the last frame it displayed before I enabled HDR.
Operating System: openSUSE Tumbleweed 20250227
KDE Plasma Version: 6.3.2
KDE Frameworks Version: 6.11.0
Qt Version: 6.8.2
Kernel Version: 6.13.4-1-default (64-bit)
Graphics Platform: Wayland
Processors: 16 × AMD Ryzen 7 5800X 8-Core Processor
Memory: 62.7 Gibyte of RAM
Graphics Processor: NVIDIA GeForce RTX 2080 Ti
Manufacturer: ASUS
nvidia-bug-report.log.gz (1.8 MB)
I can’t enable HDR on Arch Linux with 5060. Using Wayland and Gnome. 3060 works fine.
This same issue is still around in driver 595
Did some more testing of this. I am now using the open kernel driver. Doesn’t seem like proprietary driver 595 is packaged in OpenSUSE, so I downgraded to driver 580 to try proprietary again there. On 580, this happens with both the open driver, the proprietary driver with GSP and the proprietary driver without GSP, and as mentioned, on 595 this happens at least with the open driver, which is the only one I’ve tried.
I now also tried enabling HDR on only one monitor. Previously I’d tried enabling it on both at the same time. I am able to enable HDR just fine on the Acer monitor, as well as on my TV (a Philips 42OLED809/12 connected via a DP-HDMI-adapter). But when I try to enable HDR on the Gigabyte monitor, I get the above problem. The image on the Acer monitor and TV freezes and the Gigabyte monitor loses signal. To rule out the port, I also tried moving the Gigabyte monitor to a different DP output, and got the same result there. I am able to use HDR on the same monitor on the same PC on Windows.
Updated nvidia-bug-report:
nvidia-bug-report.log.gz (726.4 KB)
