I am using the following pipeline
filesrc location="/video.mp4" !
qtdemux name=demux demux. ! queue name=q_video ! h265parse !
nvv4l2decoder enable-max-performance=true !
videorate drop-only=true max-rate=30 !
nvvidconv flip-method=3 !
video/x-raw(memory:NVMM),width=(int)720,height=(int)1280,format=(string)P010_10LE,colorimetry=(string)bt2020,transfer-function=(string)smpte2084,range=(string)full,pixel-aspect-ratio=1/1 !
nvv4l2h265enc idrinterval=30 iframeinterval=30 preset-level=3 profile=1 insert-vui=true insert-sps-pps=true insert-aud=true control-rate=0 EnableTwopassCBR=true bitrate=3041280 peak-bitrate=6082560 maxperf-enable=true !
h265parse ! video/x-h265 !
hlssink2 playlist-location="/app/video.m3u8" playlist-length=0 location="/app/segment_%05d.ts" target-duration=15 max-files=1000 send-keyframe-requests=true name=sink demux. !
queue name=q_audio ! avdec_aac ! audioresample ! audioconvert ! voaacenc ! aacparse ! queue ! sink.audio
Here is the ffprobe from the generated file:
ffprobe -v error -show_streams segment.ts
[STREAM]
index=0
codec_name=hevc
codec_long_name=H.265 / HEVC (High Efficiency Video Coding)
profile=Main
codec_type=video
codec_tag_string=[36][0][0][0]
codec_tag=0x0024
width=720
height=1280
coded_width=736
coded_height=1280
closed_captions=0
film_grain=0
has_b_frames=0
sample_aspect_ratio=N/A
display_aspect_ratio=N/A
pix_fmt=yuv420p
level=93
color_range=tv
color_space=gbr
color_transfer=reserved
color_primaries=reserved
chroma_location=left
field_order=unknown
refs=1
view_ids_available=
view_pos_available=
ts_id=1
ts_packetsize=188
id=0x41
r_frame_rate=30/1
avg_frame_rate=30/1
time_base=1/90000
start_pts=324000000
start_time=3600.000000
duration_ts=875968
duration=9.732978
bit_rate=N/A
max_bit_rate=N/A
bits_per_raw_sample=N/A
nb_frames=N/A
nb_read_frames=N/A
nb_read_packets=N/A
extradata_size=92
DISPOSITION:default=0
DISPOSITION:dub=0
DISPOSITION:original=0
DISPOSITION:comment=0
DISPOSITION:lyrics=0
DISPOSITION:karaoke=0
DISPOSITION:forced=0
DISPOSITION:hearing_impaired=0
DISPOSITION:visual_impaired=0
DISPOSITION:clean_effects=0
DISPOSITION:attached_pic=0
DISPOSITION:timed_thumbnails=0
DISPOSITION:non_diegetic=0
DISPOSITION:captions=0
DISPOSITION:descriptions=0
DISPOSITION:metadata=0
DISPOSITION:dependent=0
DISPOSITION:still_image=0
DISPOSITION:multilayer=0
[/STREAM]
[STREAM]
index=1
codec_name=aac
codec_long_name=AAC (Advanced Audio Coding)
profile=LC
codec_type=audio
codec_tag_string=[15][0][0][0]
codec_tag=0x000f
sample_fmt=fltp
sample_rate=48000
channels=2
channel_layout=stereo
bits_per_sample=0
initial_padding=0
ts_id=1
ts_packetsize=188
id=0x42
r_frame_rate=0/0
avg_frame_rate=0/0
time_base=1/90000
start_pts=324001116
start_time=3600.012400
duration_ts=871953
duration=9.688367
bit_rate=130635
max_bit_rate=N/A
nb_frames=N/A
nb_read_frames=N/A
nb_read_packets=N/A
DISPOSITION:dub=0
TAG:language=en
[/STREAM]
The video is encoded successfully, but in ExoPlayer (Android) I see a green bar on the right side of the video. I’m guessing it might be something with the coded width / height, but I don’t know how to fix it.
