Hi, I’m not able to render the male head.
I’m using a GTX 1060 6GB, I know it has no RTX but in the minimum requirements appears as compatible.
Also updated drivers to latest 471.68
¿Could it be that I’m missing something?
Hi, Thank you for your interest in Audio2Face. Unfortunately in the minimum requirement, it does require an RTX card. So this won’t work with GTX 1060.
Hi, I also got a 1660 GTX, could I make it to run there?
Hello @xabiertxo42!
Omniverse requires the RTX tensor cores that are only available on our RTX cards. You need at least an RTX 2070. Here is a link to our min specs: https://docs.omniverse.nvidia.com/app_create/app_create/requirements.html#omniverse-create-requirements
