I Cant Use Nvidia Omniverse When I open audio2face there is all gray viewport and in the left bottom corner it shows failed to create Hydra enigine for viewport.
Im using Quadro P100 GPU.
Hello @abubakar493.pro! Unfortunately, your GPU is not supported on Omniverse because it lacks the Ray Tracing Tensor cores that are required to render Omniverse Applications, such as Audio2Face. Our minimum recommended GPU is an RTX 3070. You can take a look at our Technical Requirements here: Technical Requirements — Omniverse Create documentation
You can check out Omniverse Cloud which will allow you to use Omniverse on any device, anywhere!
