Omniverse Audio2Face doesn’t load the face mesh Please HELP
[Warning] [omni.gpu_foundation_factory.plugin] RT-capable GPU not found, switching to compatibility mode
Couldn’t acquire tokens interface and initialize default tokens.
[Error] [omni.kit.window.viewport.plugin] Failed to initialize resource manager
[omni.kit.window.viewport.plugin] Failed to prepare GPU Foundation
[Warning] [omni.usd] Failed to create Hydra Engine for viewport!
[omni.usd] No hydra engine was found with name running at tickrate -1
[Error] [gpu.foundation.plugin] No device could be created. Some known system issues:
The driver is not installed properly and requires a clean re-install.
Your GPUs do not support RayTracing: DXR or VK ray_tracing.
The driver cannot enumerate any GPU: driver, display or a docker issue. For Vulkan, test it with Vulkaninfo tool from Vulkan SDK, instead of nvidia-smi.
i get these lines in RED letters
PLEASE HELP ME
the face MESH doesn’t load
[Error] [omni.kit.window.viewport.plugin] Failed to prepare GPU Foundation
Hi @user81339
Sorry for your trouble in starting Audio2Face.
From the error message it looks like your graphic card is not supported. RTX card is required.
Can you share your system information and your current driver version?
Thank you.
