Thanks for the heads up Simon, much appreciated … Found it (Page 7).
In that case, to correct my post above … No, there isn’t a supported way to circumvent the driver. You’ll need to use a profile with at least 1GB of Frame Buffer if you’d like to use W10 with multi-monitor
Regards
Ben
