Gs_usb kernel problem on jetpack 6
Hi, nvidia export.
I’m using agx orin devloper kit(32GB) on jetpack 6.0(L4T 36.3.0).
Also, I will use robotics project so, I have to use gs_usb to USB to CAN communicate.
However,I got the error when I enabled gs_usb kernel by “sudo modprobe gs_usb”. The error is: “modprobe: FATAL: Module gs_usb not found in directory /lib/modules/5.15.136-tegra".
And my robot was not moving.
I can’t change jetpack version because, I have to use ros2 humble with my mobie robot and my camera and Lidar.
What can I do?
Please help me
First check if the module is listed in config file so that you can load using modprobe or insmod commands
Hi tmddnjs0507,
seems duplicate topic as Does jetpack 6.0 not support gs_usb(usb to can)? - Jetson & Embedded Systems / Jetson Projects - NVIDIA Developer Forums, pleas just discuss similar issue in one topic, thanks.
