The device is an Orin AGX CLB 64GB (loborobot). It works normally under JETPACK 5.1.5, but after I flashed the 6.x version using SDK Manager, although the device boots and runs properly, all USB ports are non-functional. Plugging in and unplugging the mouse, keyboard, and external hard drive does not produce any output in lsusb.
The output during boot compilation is as follows:
[ 5.756860] ucsi_ccg 1-0008: i2c_transfer failed -121
[ 5.756863] ucsi_ccg 1-0008: ucsi_ccg_init failed - -121
[ 5.756867] ucsi_ccg: probe of 1-0008 failed with error -121
sudo dmesg | grep -i usb produces the following:
jetson@ubuntu:~$ sudo dmesg | grep -i usb
[sudo] password for jetson:
[ 0.121105] usbcore: registered new interface driver usbfs
[ 0.121133] usbcore: registered new interface driver hub
[ 0.121158] usbcore: registered new device driver usb
[ 0.254562] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.254810] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.255378] usbcore: registered new interface driver usb-storage
[ 3.646584] usbcore: registered new interface driver usbhid
[ 3.646589] usbhid: USB HID core driver
[ 3.715427] usbcore: registered new interface driver snd-usb-audio
And
jetson@ubuntu:~$ lspci | grep -i usb
jetson@ubuntu:~$ ls /sys/class/usb_host
ls: cannot access ‘/sys/class/usb_host’: No such file or directory
jetson@ubuntu:~$ ls /lib/modules/$(uname -r)/kernel/drivers/usb/host | grep xusb jetson@ubuntu:~$ ls /lib/modules/$(uname -r)/kernel/drivers/usb/host | grep xusb
Are there any other details I should provide to help solve this issue? AGX is still running on 5.1.5, where everything works fine, but I would still like to upgrade to Jetpack 6 for more support. :)
