Hi!
I’m working with a Jetson Nano Dev Kit B01 and two IMX219 cameras (in a stereo like configuration) connected to each of the CSI connectors of the board. I’m using Jetpack 4.6 and ROS melodic.
Now, I want to publish the cameras’ image into ROS topics, and for that I ended up using the gscam package. The problem is that I don’t think I fully understand how to configure its parameters, and the launch file I wrote doesn’t work. My guess is that I’m not setting up the gscam_config
parameter properly, but I couldn’t find any solution.
This is the launch file I wrote so far:
<launch>
<arg name="left_camera" default=0/>
<arg name="right_camera" default=1/>
<arg name="width" default="3280"/>
<arg name="height" default="2464"/>
<arg name="fps" default="20/1"/>
<arg name="format" default="NV12"/>
<arg name="config_format" dafault="video/x-raw(memory:NVMM), width=$(arg width), height=$(arg height), format=$(arg format), framerate=$(arg fps)"/>
<group ns="left">
<node pkg="gscam" type="gscam" name="gscam" output="screen">
<param name="camera_name" value="default"/>
<param name="gscam_config" value="nvarguscamerasrc sensor-id=$(arg left_camera) ! $(arg config_format) ! nvvidconv flip-method=6"/>
<param name="camera_info_url" value="file://$(find my_stereo_camera)/config/calibration/uncalibrated_parameters.ini"/>
<param name="frame_id" value="/left_frame"/>
<param name="sync_sink" value="false"/>
<remap from="left/camera/image_raw" to="left/image_raw"/>
<remap from="left/camera/camera_info" to="left/camera_info"/>
</node>
</group>
<group ns="right">
<param name="gscam_config" value="nvarguscamerasrc sensor-id=$(arg right_camera) ! $(arg config_format) ! nvvidconv flip-method=6"/>
<param name="frame_id" value="/right_frame"/>
<remap from="right/camera/image_raw" to="right/image_raw"/>
<remap from="right/camera/camera_info" to="right/camera_info"/>
</node>
</group>
</launch>
Any clue of what could I be missing?
Also, I tested both cameras with the following command in the terminal:
DISPLAY=:0.0 gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! 'video/x-raw(memory:NVMM), width=3280, height=2464, format=(string)NV12, framerate=(fraction)20/1' ! nvoverlaysink -e
