GST-NVVIDEOCONVERT
I am reading GST-NVVIDEOCONVERT in DS4.0 PlugIn Manual and testing Gst Properties,
I think this plugin can crop an image from input or output surface
How do I use this function ? Do you have examples?
Please configure the properties:
src-crop            : Pixel location left:top:width:height
                    Use string with values of crop location to set the property.
                     e.g. 20:20:40:50
                    flags: readable, writable, changeable only in NULL or READY state
                    String. Default: "0:0:0:0"
dest-crop           : Pixel location left:top:width:height
                     e.g. 20:20:40:50
Thanks for your help but I already used these properties
connected Plugin list below
… streammux, pgie, nvtracker, sgie1, sgie2, sgie3, nvvidconv, nvosd, transform, sink
so I hope to crop image between nvvidconv and nvosd
just try to change state ? e.g gst_element_set_state (pipeline, GST_STATE_READY);
On DS4.0, please use nvvideoconvert instead of nvvidconv.
A relevant post:
[url]nvvidconv vs nvvideoconvert (DS 4.0 Nano) - DeepStream SDK - NVIDIA Developer Forums
Your pipeline should be from deepstream-test2. For your case, you can configure dest-crop to nvvidconv and add capsfilter between nvvidconv and nvosd to specify after-crop width and height.
Thanks for your reply,
my pipeline based on deepstream-test2 was working in DS4.0 and I used nvvideoconvert instead of nvvidconv
I did test about nvvideoconvert by setting properties, nvbuf-memory-type, src-crop, dst-crop but it did not work well,
Could you give me advice if you know how to use it?
I used capsfilter because of nvvidconv when I used deepstream-test2 in DS3.0
but now I changed to nvvideoconvert in DS.40 and I don’t use capsfilter anymore
now I checked capsfilter by using gst-inspect-1.0 but I didn’t find something about the crop
Element Properties:
  name                : The name of the object
                        String. Default: "capsfilter0"
  parent              : The parent of the object
                        Object of type "GstObject"
  qos                 : Handle Quality-of-Service events
                        Boolean. Default: false
  caps                : Restrict the possible allowed capabilities (NULL means ANY). Setting this property takes a reference to the supplied GstCaps object.
                        flags: readable, writable, changeable in NULL, READY, PAUSED or PLAYING state
                                                   ANY
  caps-change-mode    : Filter caps change behaviour
                        Enum "GstCapsFilterCapsChangeMode" Default: 0, "immediate"
                           (0): immediate        - Only accept the current filter caps
                           (1): delayed          - Temporarily accept previous filter caps
Please set dst-crop to 20:20:320:240 and insert capsfilter=‘video/x-raw(memory:NVMM),width=320,height=240’ into nvvidconv and nvosd. If you still hit error, please share a patch on deepstream-test2 to let us reproduce the error.
