We are trying to update from JP 3.3 to 4.2 for the Jetson Tx2 with our custom carrier board and imx219 camera.
we compile source L4T32.2.1,v4l2 video node is OK,
ls /dev/vid*
/dev/video0
v4l2-ctl -V
Format Video Capture:
Width/Height : 1920/1080
Pixel Format : 'RG10'
Field : None
Bytes per Line : 3840
Size Image : 4147200
Colorspace : sRGB
Transfer Function : Default (maps to sRGB)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Full Range)
Flags :
v4l2-ctl -d /dev/video0 --list-formats
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: 'RG10'
Name : 10-bit Bayer RGRG/GBGB
we can capture camera without error,using v4l2 ::
v4l2-ctl --set-fmt-video=width=1920,height=1080,pixelformat=RG10 --stream-mmap --stream-count=1 -d /dev/video0 --stream-to=imx219.raw
but when execute this command:
FILE=filename.mp4
gst-launch-1.0 -e nvarguscamerasrc ! 'video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1' \
! nvvidconv ! 'video/x-raw(memory:NVMM), format=(string)I420' ! omxh264enc bitrate=8000000 ! 'video/x-h264, stream-format=(string)byte-stream' \
! h264parse ! qtmux ! filesink location=$FILE -e
See NvArgusCameraSrc function error output:
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:521 No cameras available
Got EOS from element "pipeline0".
My question is How do I fix this?
Thank you!!
