Gstnvtracker: Optional NvMOT_RetrieveMiscData not implemented
I got this issue also. But I don’t know how it’s solved in below link.
Can you help to direct me to the right channel or way to fix the issue?
daniel@daniel-nvidia:~/Work/jetson-fpv/utils/dsyolo$ deepstream-app -c source_config_yolov8s.txt
** WARN: <parse_tracker:1604>: Unknown key 'enable-batch-process' for group [tracker]
gstnvtracker: Loading low-level lib at /home/daniel/Work/jetson-fpv/utils/dsyolo/libByteTracker.so
gstnvtracker: Optional NvMOT_RetrieveMiscData not implemented
[BYTETrack Initialized]
gstnvtracker: Only batch processing mode is supported. query.batchMode must be set as NvMOTBatchMode_Batch
gstnvtracker: Failed to initilaize low level lib.
** ERROR: <main:716>: Failed to set pipeline to PAUSED
Quitting
nvstreammux: Successfully handled EOS for source_id=0
App run failed
daniel@daniel-nvidia:~/Work/jetson-fpv/utils/dsyolo$ ls /home/daniel/Work/jetson-fpv/utils/dsyolo/libByteTracker.so
  • Jetson Orin Nano 8GB
Software part of jetson-stats 4.2.12 - (c) 2024, Raffaello Bonghi
Model: NVIDIA Orin Nano Developer Kit - Jetpack 5.1.4 [L4T 35.6.0]
NV Power Mode[0]: 15W
Serial Number: [XXX Show with: jetson_release -s XXX]
Hardware:
 - P-Number: p3767-0005
 - Module: NVIDIA Jetson Orin Nano (Developer kit)
Platform:
 - Distribution: Ubuntu 20.04 focal
 - Release: 5.10.216-tegra
jtop:
 - Version: 4.2.12
 - Service: Active
Libraries:
 - CUDA: 11.4.315
 - cuDNN: 8.6.0.166
 - TensorRT: 8.5.2.2
 - VPI: 2.4.8
 - OpenCV: 4.9.0 - with CUDA: YES
DeepStream C/C++ SDK version: 6.3
Python Environment:
Python 3.8.10
    GStreamer:                   YES (1.16.3)
  NVIDIA CUDA:                   YES (ver 11.4, CUFFT CUBLAS FAST_MATH)
        OpenCV version: 4.9.0  CUDA True
          YOLO version: 8.3.33
         Torch version: 2.1.0a0+41361538.nv23.06
   Torchvision version: 0.16.1+fdea156
DeepStream SDK version: 1.1.8
Seems you use the libByteTracker.so. We have the guide for customize the low level tracker library: Gst-nvtracker — DeepStream documentation. We also released the nvtracker plugin code here: /opt/nvidia/deepstream/deepstream-7.1/sources/gst-plugins/gst-nvtracker/. You can debug the fail with those source code.
OK, it seems all end up here.
Suggest to use Weak Symbols in Dynamic Linking, which is comparatively easier to maintain
