Gstreamer-1.0 playbin can't show video
Hi everyone
I used gstreamer-1.0 playbin to play a mp4 file, but it can’t show video, only output audio. I had print GST_DEBUG information but I can’t find some helpful log, is it problem?
Thanks in advice.
You’ll probably need to give the L4T release, exact gstreamer command line, and any information (if possible) on the video format for anyone to be able to provide information.
My TK1 version is R21.4, and install gstreamer1.0 with
sudo apt-get install gstreamer1.0-tools gstreamer1.0-alsa gstreamer1.0-plugins-base gstreamer1.0-plugins-good gstreamer1.0-plugins-bad gstreamer1.0-plugins-ugly gstreamer1.0-libav
The test MP4 file is from http://sample-videos.com/
I downloaded the first one, 1.1MB size, 1080x720 resolution.
Format as following with avprobe filename.mp4 (sudo apt-get install libav-tools)
ubuntu@tegra-ubuntu:~$ avprobe SampleVideo_1080x720_1mb.mp4
avprobe version 9.18-6:9.18-0ubuntu0.14.04.1, Copyright (c) 2007-2014 the Libav developers
  built on Mar 16 2015 13:37:34 with gcc 4.8 (Ubuntu/Linaro 4.8.2-19ubuntu1)
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'SampleVideo_1080x720_1mb.mp4':
  Metadata:
    major_brand     : isom
    minor_version   : 512
    compatible_brands: isomiso2avc1mp41
    creation_time   : 1970-01-01 00:00:00
    encoder         : Lavf53.24.2
  Duration: 00:00:05.31, start: 0.000000, bitrate: 1589 kb/s
    Stream #0.0(und): <b><u>Video: h264 (Main), yuv420p, 1280x720</u></b> [PAR 1:1 DAR 16:9], 1205 kb/s, 25 fps, 25 tbr, 12800 tbn, 50 tbc
    Metadata:
    Stream #0.1(und): Audio: aac, 48000 Hz, 5.1, fltp, 384 kb/s
    Metadata:
# avprobe output
The gstreamer version and exact command line
ubuntu@tegra-ubuntu:~$ gst-launch-1.0 --version
gst-launch-1.0 version 1.2.4
GStreamer 1.2.4
https://launchpad.net/distros/ubuntu/+source/gstreamer1.0
ubuntu@tegra-ubuntu:~$ export GST_DEBUG=*:3
ubuntu@tegra-ubuntu:~$ gst-launch-1.0 -v playbin uri=file:///home/ubuntu/SampleVideo_1080x720_1mb.mp4
Setting pipeline to PAUSED ...
/GstPlayBin:playbin0/GstURIDecodeBin:uridecodebin0: ring-buffer-max-size = 0
/GstPlayBin:playbin0/GstURIDecodeBin:uridecodebin0: buffer-size = -1
/GstPlayBin:playbin0/GstURIDecodeBin:uridecodebin0: buffer-duration = -1
/GstPlayBin:playbin0/GstURIDecodeBin:uridecodebin0: use-buffering = false
/GstPlayBin:playbin0/GstURIDecodeBin:uridecodebin0: download = false
/GstPlayBin:playbin0/GstURIDecodeBin:uridecodebin0: uri = file:///home/ubuntu/SampleVideo_1080x720_1mb.mp4
/GstPlayBin:playbin0/GstURIDecodeBin:uridecodebin0: connection-speed = 0
/GstPlayBin:playbin0/GstURIDecodeBin:uridecodebin0: source = "\(GstFileSrc\)\ source"
Pipeline is PREROLLING ...
/GstPlayBin:playbin0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstTypeFindElement:typefind.GstPad:src: caps = video/quicktime, variant=(string)iso
/GstPlayBin:playbin0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstTypeFindElement:typefind.GstPad:src: caps = NULL
0:00:00.171646416  2438 0xb56392c0 WARN                 qtdemux qtdemux.c:7977:qtdemux_parse_trak:<qtdemux0> unknown version 00000000
/GstPlayBin:playbin0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstMultiQueue:multiqueue0: max-size-buffers = 5
/GstPlayBin:playbin0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstMultiQueue:multiqueue0: max-size-time = 0
/GstPlayBin:playbin0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstMultiQueue:multiqueue0: max-size-bytes = 2097152
/GstPlayBin:playbin0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstMultiQueue:multiqueue0.GstPad:src_0: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, level=(string)3.1, profile=(string)main, codec_data=(buffer)014d401fffe10017674d401fda014016ec0440000003004000000c83c60ca801000468ef3c80, width=(int)1280, height=(int)720, framerate=(fraction)25/1, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin:playbin0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstMultiQueue:multiqueue0.GstPad:sink_0: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, level=(string)3.1, profile=(string)main, codec_data=(buffer)014d401fffe10017674d401fda014016ec0440000003004000000c83c60ca801000468ef3c80, width=(int)1280, height=(int)720, framerate=(fraction)25/1, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin:playbin0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstMultiQueue:multiqueue0.GstPad:sink_1: caps = audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)4, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)11b0, rate=(int)48000, channels=(int)6, channel-mask=(bitmask)0x0000000000000000
/GstPlayBin:playbin0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstH264Parse:h264parse0.GstPad:sink: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, level=(string)3.1, profile=(string)main, codec_data=(buffer)014d401fffe10017674d401fda014016ec0440000003004000000c83c60ca801000468ef3c80, width=(int)1280, height=(int)720, framerate=(fraction)25/1, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin:playbin0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstH264Parse:h264parse0.GstPad:src: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3.1, profile=(string)main, width=(int)1280, height=(int)720, framerate=(fraction)25/1, pixel-aspect-ratio=(fraction)1/1, parsed=(boolean)true
0:00:00.255417500  2438   0x167af0 WARN                     omx /dvs/git/dirty/git-master_linux/external/gstreamer/gst-omx/omx/gstomx.c:2785:plugin_init: Failed to load configuration file: Valid key file could not be found in search dirs (searched in: /home/ubuntu/.config:/etc/xdg/xdg-ubuntu:/usr/share/upstart/xdg:/etc/xdg as per GST_OMX_CONFIG_DIR environment variable, the xdg user config directory (or XDG_CONFIG_HOME) and the system config directory (or XDG_CONFIG_DIRS)
Inside NvxLiteH264DecoderLowLatencyInitNvxLiteH264DecoderLowLatencyInit set DPB and Mjstreaming/GstPlayBin:playbin0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3.1, profile=(string)main, width=(int)1280, height=(int)720, framerate=(fraction)25/1, pixel-aspect-ratio=(fraction)1/1, parsed=(boolean)true
/GstPlayBin:playbin0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstOMXH264Dec-omxh264dec:omxh264dec-omxh264dec0.GstPad:sink: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3.1, profile=(string)main, width=(int)1280, height=(int)720, framerate=(fraction)25/1, pixel-aspect-ratio=(fraction)1/1, parsed=(boolean)true
/GstPlayBin:playbin0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3.1, profile=(string)main, width=(int)1280, height=(int)720, framerate=(fraction)25/1, pixel-aspect-ratio=(fraction)1/1, parsed=(boolean)true
NvMMLiteOpen : Block : BlockType = 261
TVMR: NvMMLiteTVMRDecBlockOpen: 4937: NvMMLiteBlockOpen
/GstPlayBin:playbin0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstAacParse:aacparse0.GstPad:src: caps = audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)4, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)11b0, rate=(int)48000, channels=(int)6, channel-mask=(bitmask)0x0000000000000000
The monitor I use for direct access on Jetson isn’t actually capable of 1080x720, so I used the similar file SampleVideo_720x480_1mb.mp4 for test as a way to avoid any possible problem from that. I recognize the steps to be directly out of “L4T_Jetson_TK1_Multimedia_User_Guide.pdf”, which could possibly be out of date (I don’t know enough about it to say) and in need of additional information.
I can verify that this sends audio but not video. There may be additional issues when run without sudo, which shouldn’t be the case.
Can anyone here verify what changes would need to be made to the Multimedia User Guide if this is at fault for outdated information? See:
http://developer.download.nvidia.com/embedded/L4T/r21_Release_v4.0/Tegra_Linux_Driver_Package_Documents_R21.4.tar
Sample MP4s used:
To play video playback with gstreamer-1.0, please use nvgstplayer-1.0 -i /home/ubuntu/SampleVideo_1080x720_1mb.mp4. You can refer to p.16 in Jetson TK1/Tegra Linux Driver Package Multimedia User Guide.pdf.
I can play this mp4 file with the above command in Sony 1080p TV. Model: KDL-40X200A
