Hi
I connected IMX415 camera sensor in Jetson nano and done device tree and driver configuration.I was able to get the v4lt-tools based raw image capture from the sensor. So this means that the device tree configuration and the video path is working. I am getting the kernel log as the “imx415 detected” as well as the /dev/video0 node.But when I tried to fetch video from camera using gstreamer pipeline it is throwing an error:no cameras available.
Pipeline used and error log is mentioned below.
“gst-launch-1.0 nvarguscamerasrc sensor-id=0! ‘video/x-raw(memory:NVMM), width=(int)3840, height=(int)2160, framerate=16/1’ ! nvvidconv flip-method=0 ! ‘video/x-raw, format=(string)I420’ ! xvimagesink-e”
Error Log :
gst-launch-1.0 nvarguscamerasrc ! ‘video/x-raw(memory:NVMM), width=(int)3840, height=(int)2160, framerate=16/1’ ! nvvidconv flip-method=0 ! ‘video/x-raw, format=(string)I420’ ! xvimagesink -e
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstSystemClock
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:557 No cameras available
Got EOS from element “pipeline0”.
Execution ended after 0:00:00.776537135
Setting pipeline to READY …
Setting pipeline to NULL …
Freeing pipeline …
Please help me.
Thanks in advance
It could be the tegra-camera-platform context of the device tree have problem cause “No cameras available”
And have you verify the “v4l2-ctl --stream-mmap --stream-count=100 -d /dev/video0” to confirm the sensor driver?
Hi
Thanks for your reply.I tried with the v4l2-ctl --stream-mmap --stream-count=100 -d /dev/video0
The log I am getting is given below
<<<<<<<<<<<<<<<<<< 16.83 fps
<<<<<<<<<<<<<<<<< 16.74 fps
<<<<<<<<<<<<<<<<< 16.72 fps
<<<<<<<<<<<<<<<< 16.70 fps
<<<<<<<<<<<<<<<<< 16.69 fps
v4l2-ctl --list-devices
vi-output, imx415 6-001a (platform:54080000.vi:0):
/dev/video0
The .dtsi file
#include <dt-bindings/media/camera.h>
#include <dt-bindings/platform/t210/t210.h>
host1x {
vi_base: vi {
num-channels = <1>;
ports {
#address-cells = <1>;
#size-cells = <0>;
vi_port0: port@0 {
reg = <0>;
rbpcv2_imx415_vi_in0: endpoint {
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&rbpcv2_imx415_csi_out0>;
csi_base: nvcsi {
num-channels = <1>;
#size-cells = <0>;
csi_chan0: channel@0 {
reg = <0>;
ports {
#size-cells = <0>;
csi_chan0_port0: port@0 {
reg = <0>;
rbpcv2_imx415_csi_in0: endpoint@0 {
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&rbpcv2_imx415_out0>;
csi_chan0_port1: port@1 {
reg = <1>;
rbpcv2_imx415_csi_out0: endpoint@1 {
remote-endpoint = <&rbpcv2_imx415_vi_in0>;
i2c@546c0000 {
imx415_single_cam0: rbpcv2_imx415_a@1a {
compatible = "nvidia,imx415";
/* I2C device address */
reg = <0x1a>;
/* V4L2 device node location */
devnode = "video0";
/* Physical dimensions of sensor */
physical_w = "3.680";
physical_h = "2.760";
sensor_model = "imx415";
/* Defines number of frames to be dropped by driver internally after applying */
/* sensor crop settings. Some sensors send corrupt frames after applying */
/* crop co-ordinates */
/* post_crop_frame_drop = "0"; */
/* Convert Gain to unit of dB (decibel) befor passing to kernel driver */
/* use_decibel_gain = "true"; */
/* if true, delay gain setting by one frame to be in sync with exposure */
/* delayed_gain = "true"; */
/* enable CID_SENSOR_MODE_ID for sensor modes selection */
use_sensor_mode_id = "true";
* ==== Modes ====
* A modeX node is required to support v4l2 driver
* implementation with NVIDIA camera software stack
* == Signal properties ==
* phy_mode = "";
* PHY mode used by the MIPI lanes for this device
* tegra_sinterface = "";
* CSI Serial interface connected to tegra
* Incase of virtual HW devices, use virtual
* For SW emulated devices, use host
* pix_clk_hz = "";
* Sensor pixel clock used for calculations like exposure and framerate
* readout_orientation = "0";
* Based on camera module orientation.
* Only change readout_orientation if you specifically
* Program a different readout order for this mode
* == Image format Properties ==
* active_w = "";
* Pixel active region width
* active_h = "";
* Pixel active region height
* pixel_t = "";
* The sensor readout pixel pattern
* line_length = "";
* Pixel line length (width) for sensor mode.
* == Source Control Settings ==
* Gain factor used to convert fixed point integer to float
* Gain range [min_gain/gain_factor, max_gain/gain_factor]
* Gain step [step_gain/gain_factor is the smallest step that can be configured]
* Default gain [Default gain to be initialized for the control.
* use min_gain_val as default for optimal results]
* Framerate factor used to convert fixed point integer to float
* Framerate range [min_framerate/framerate_factor, max_framerate/framerate_factor]
* Framerate step [step_framerate/framerate_factor is the smallest step that can be configured]
* Default Framerate [Default framerate to be initialized for the control.
* use max_framerate to get required performance]
* Exposure factor used to convert fixed point integer to float
* For convenience use 1 sec = 1000000us as conversion factor
* Exposure range [min_exp_time/exposure_factor, max_exp_time/exposure_factor]
* Exposure step [step_exp_time/exposure_factor is the smallest step that can be configured]
* Default Exposure Time [Default exposure to be initialized for the control.
* Set default exposure based on the default_framerate for optimal exposure settings]
* gain_factor = ""; (integer factor used for floating to fixed point conversion)
* min_gain_val = ""; (ceil to integer)
* max_gain_val = ""; (ceil to integer)
* step_gain_val = ""; (ceil to integer)
* default_gain = ""; (ceil to integer)
* Gain limits for mode
* exposure_factor = ""; (integer factor used for floating to fixed point conversion)
* min_exp_time = ""; (ceil to integer)
* max_exp_time = ""; (ceil to integer)
* step_exp_time = ""; (ceil to integer)
* default_exp_time = ""; (ceil to integer)
* Exposure Time limits for mode (sec)
* framerate_factor = ""; (integer factor used for floating to fixed point conversion)
* min_framerate = ""; (ceil to integer)
* max_framerate = ""; (ceil to integer)
* step_framerate = ""; (ceil to integer)
* default_framerate = ""; (ceil to integer)
* Framerate limits for mode (fps)
* embedded_metadata_height = "";
* Sensor embedded metadata height in units of rows.
* If sensor does not support embedded metadata value should be 0.
mode0 {/*mode IMX415_MODE_3840X2160_22FPS*/
mclk_khz = "37125";
num_lanes = "2";
phy_mode = "DPHY";
discontinuous_clk = "no";
dpcm_enable = "false";
cil_settletime = "0";
dynamic_pixel_bit_depth = "12";
csi_pixel_bit_depth = "12";
mode_type = "bayer";
pixel_phase = "gbrg";
active_w = "3840"; // 12+3840+12, but cropping to 3840
active_h = "2160"; // 1+2+8+2160+8+12+1, but cropping to 2160
line_length = "3980";
inherent_gain = "1";
mclk_multiplier = "4";
pix_clk_hz = "148500000";
gain_factor = "100";
min_gain_val = "0"; /* 0dB */
max_gain_val = "7200"; /* 72dB */
step_gain_val = "1"; /* 0.01 */
default_gain = "0";
min_hdr_ratio = "1";
max_hdr_ratio = "1";
framerate_factor = "1000000";
min_framerate = "16670000";
max_framerate = "16670000";
step_framerate = "1";
default_framerate = "16670000";
exposure_factor = "1000000";
min_exp_time = "111"; /* us */
max_exp_time = "44663"; /* us */
step_exp_time = "1";
default_exp_time = "3000";/* us */
embedded_metadata_height = "1";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
rbpcv2_imx415_out0: endpoint {
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&rbpcv2_imx415_csi_in0>;
lens_imx415@RBPCV2 {
min_focus_distance = "0.0";
hyper_focal = "0.0";
focal_length = "3.04";
f_number = "2.0";
aperture = "0.0";
tcp: tegra-camera-platform {
compatible = “nvidia, tegra-camera-platform”;
* Physical settings to calculate max ISO BW
* num_csi_lanes = <>;
* Total number of CSI lanes when all cameras are active
* max_lane_speed = <>;
* Max lane speed in Kbit/s
* min_bits_per_pixel = <>;
* Min bits per pixel
* vi_peak_byte_per_pixel = <>;
* Max byte per pixel for the VI ISO case
* vi_bw_margin_pct = <>;
* Vi bandwidth margin in percentage
* max_pixel_rate = <>;
* Max pixel rate in Kpixel/s for the ISP ISO case
* isp_peak_byte_per_pixel = <>;
* Max byte per pixel for the ISP ISO case
* isp_bw_margin_pct = <>;
* Isp bandwidth margin in percentage
num_csi_lanes = <12>;
max_lane_speed = <1500000>;
min_bits_per_pixel = <10>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
max_pixel_rate = <240000>;
isp_peak_byte_per_pixel = <5>;
isp_bw_margin_pct = <25>;
* The general guideline for naming badge_info contains 3 parts, and is as follows,
* The first part is the camera_board_id for the module; if the module is in a FFD
* platform, then use the platform name for this part.
* The second part contains the position of the module, ex. "rear" or "front".
* The third part contains the last 6 characters of a part number which is found
* in the module's specsheet from the vendor.
modules {
cam_module0: module0 {
badge = "porg_bottomleft_RBPCV2";
position = "bottomleft";
orientation = "0";
cam_module0_drivernode0: drivernode0 {
pcl_id = "v4l2_sensor";
devname = "imx415 30-001a";
proc-device-tree = "/proc/device-tree/host1x/i2c@546c0000/rbpcv2_imx415_a@1a";
cam_module0_drivernode1: drivernode1 {
pcl_id = "v4l2_lens";
proc-device-tree = "/proc/device-tree/lens_imx415@RBPCV2/";
Could you please help me?
The devname is incorrect. The bus# should be 6 instead of 30
devname = “imx415 30-001a”
Thank you so much .I changed the devname and it is working fine now.
