Gstreamer deepstream using too much cpu
• Hardware Platform (Jetson / GPU) GPU rtx2080ti
• DeepStream Version 5.1
• NVIDIA GPU Driver Version (valid for GPU only) 460
hello. i sucessful read videostream using gstreamer deepstream. but cpu is high
Warning: gst-stream-error-quark: No decoder available for type 'application/x-rtp, media=(string)application, payload=(int)107, clock-rate=(int)90000, encoding-name=(string)VND.ONVIF.METADATA, a-tool=(string)"Streaming\ Media\ v2010.05.25", a-type=(string)broadcast, a-recvonly=(string)"", clock-base=(uint)62851, seqnum-base=(uint)64401, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1, ssrc=(uint)411825539'. (6): gsturidecodebin.c(921): unknown_type_cb (): /GstPipeline:pipeline0/GstBin:source-bin-00/GstURIDecodeBin:uri-decode-bin
https://gist.github.com/ThiagoMateo/bb304ce8960742f2e14d6bbba34b55c9
What do you want? Have you identified which part use most CPU?
