I ran the deepstream-app with the default config files on native Ubuntu 18.04 and on the Docker running on the same machine again for two different config files:
source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt
source30_1080p_dec_infer-resnet_tiled_display_int8.txt
The performance difference between the native Ubuntu and Docker is seen. However, the difference in CPU and GPU utilization is marginal )if not huge). However, the difference in GPU utilization for Source4 and Sourc30 config files is huge on the same environment (either native Ubuntu or Docker). I am not sure if this due to number of sources OR due to the type of interences these two config files are catering to or it it due to both of these reasons? Also, is the CPU utilization is high (when observed using ‘top’). Is it correct to assume that it is because the CPU is busy reading the files and feeding the GPU or is there any reason?
These seem to be basic questions as we are trying to understand the possible scenarios so that we can configure the system optimally. If you can provide some inputs, it will be helpful.
deepstream-app built on native UBUNTU
Results of using source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt
| NVIDIA-SMI 440.64.00 Driver Version: 440.64.00 CUDA Version: 10.2 |
| 0 GeForce RTX 208… On | 00000000:09:00.0 Off | N/A |
| 49% 69C P2 126W / 250W | 1379MiB / 11018MiB | 39% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 2220 G /usr/lib/xorg/Xorg 18MiB |
| 0 2358 G /usr/bin/sddm-greeter 33MiB |
| 0 3546 C deepstream-app 1184MiB |
**PERF: 188.18 (166.42) 188.18 (166.42) 188.18 (166.42) 188.18 (166.42)
**PERF: 187.08 (166.17) 187.08 (166.17) 187.08 (166.17) 187.08 (166.17)
**PERF: 109.96 (164.84) 109.96 (164.84) 109.96 (164.84) 109.96 (164.84)
**PERF: 187.05 (165.56) 187.05 (165.56) 187.05 (165.56) 187.05 (165.56)
**PERF: 109.18 (163.78) 109.18 (163.78) 109.18 (163.78) 109.18 (163.78)
**PERF: 187.10 (164.49) 187.10 (164.49) 187.10 (164.49) 187.10 (164.49)
**PERF: 116.87 (163.08) 116.87 (163.08) 116.87 (163.08) 116.87 (163.08)
**PERF: 115.72 (161.72) 115.72 (161.72) 115.72 (161.72) 115.72 (161.72)
**PERF: 109.78 (160.26) 109.78 (160.26) 109.78 (160.26) 109.78 (160.26)
**PERF: 185.02 (160.94) 185.02 (160.94) 185.02 (160.94) 185.02 (160.94)
**PERF: 107.01 (159.50) 107.01 (159.50) 107.01 (159.50) 107.01 (159.50)
**PERF: 185.10 (160.16) 185.10 (160.16) 185.10 (160.16) 185.10 (160.16)
**PERF: 104.13 (158.75) 104.13 (158.75) 104.13 (158.75) 104.13 (158.75)
Results of using source30_1080p_dec_infer-resnet_tiled_display_int8.txt :
| 51% 70C P2 123W / 250W | 2770MiB / 11018MiB | 12% Default |
| 0 3680 C deepstream-app 2576MiB |
**PERF: 24.95 (21.71) 24.95 (21.76) 24.95 (21.74) 24.72 (21.70) 24.72 (21.74) 25.19 (21.74) 24.95 (21.69) 25.18 (21.67) 24.95 (21.74) 24.72 (21.73) 24.95 (21.74) 24.95 (21.76) 24.95 (21.71) 24.95 (21.72) 25.18 (21.71)24.95 (21.74) 24.95 (21.75) 24.72 (21.68) 24.72 (21.70) 24.95 (21.71) 24.95 (21.71) 24.72 (21.68) 24.95 (21.74)24.95 (21.76) 24.95 (21.72) 24.72 (21.74) 24.95 (21.76) 24.95 (21.72) 24.95 (21.74) 24.95 (21.75)
**PERF: 19.44 (21.66) 19.63 (21.72) 19.48 (21.70) 19.67 (21.67) 19.48 (21.70) 19.52 (21.71) 19.48 (21.65) 19.81 (21.64) 19.48 (21.70) 19.67 (21.70) 19.67 (21.72) 19.48 (21.72) 19.63 (21.67) 19.58 (21.67) 19.48 (21.68)19.48 (21.70) 19.48 (21.71) 19.67 (21.65) 19.67 (21.67) 19.67 (21.68) 19.63 (21.67) 19.63 (21.64) 19.63 (21.70)19.48 (21.72) 19.48 (21.68) 19.48 (21.70) 19.63 (21.72) 19.48 (21.68) 19.48 (21.70) 19.67 (21.72)
**PERF: 21.22 (21.69) 21.22 (21.74) 21.19 (21.71) 21.19 (21.69) 21.00 (21.70) 21.38 (21.74) 21.38 (21.68) 21.22 (21.67) 21.19 (21.71) 21.58 (21.73) 21.19 (21.73) 21.19 (21.73) 21.03 (21.69) 21.06 (21.70) 21.19 (21.69)21.38 (21.73) 21.19 (21.72) 21.19 (21.67) 21.00 (21.68) 21.38 (21.70) 21.03 (21.69) 21.22 (21.67) 21.22 (21.72)21.58 (21.75) 21.58 (21.71) 21.00 (21.70) 21.41 (21.75) 21.38 (21.70) 21.58 (21.73) 21.19 (21.73)
Running deepstream-app on NVIDIA 5.0 DOCKER (-devel)
Results for source30_1080p_dec_infer-resnet_tiled_display_int8.txt:
| 37% 62C P2 115W / 250W | 2770MiB / 11018MiB | 13% Default |
| 0 4721 C deepstream-app 2576MiB |
**PERF: 24.35 (25.18) 24.55 (25.21) 24.35 (25.23) 24.75 (25.23) 24.55 (25.18) 24.55 (25.21) 24.75 (25.18) 24.55 (25.18) 24.55 (25.20) 24.55 (25.22) 24.35 (25.23) 24.75 (25.23) 24.75 (25.19) 24.55 (25.20) 24.55 (25.22) 24.55 (25.22) 24.75 (25.18) 24.95 (25.23) 24.55 (25.23) 24.55 (25.22) 24.55 (25.22) 24.55 (25.22) 24.75 (25.23) 24.55 (25.18) 24.75 (25.21) 24.75 (25.19) 24.75 (25.24) 24.55 (25.20) 24.55 (25.18) 24.55 (25.22)
**PERF: 25.43 (25.20) 25.43 (25.23) 25.43 (25.24) 25.43 (25.24) 25.43 (25.20) 25.43 (25.23) 25.43 (25.20) 25.43 (25.20) 25.43 (25.22) 25.63 (25.24) 25.43 (25.24) 25.43 (25.24) 25.43 (25.22) 25.43 (25.22) 25.63 (25.24) 25.63 (25.24) 25.43 (25.19) 25.64 (25.23) 25.43 (25.24) 25.63 (25.24) 25.43 (25.24) 25.63 (25.24) 25.43 (25.24) 25.43 (25.20) 25.43 (25.23) 25.43 (25.21) 25.43 (25.25) 25.43 (25.22) 25.63 (25.21) 25.63 (25.24)
**PERF: 25.52 (25.21) 25.52 (25.24) 25.52 (25.25) 25.32 (25.24) 25.32 (25.20) 25.52 (25.24) 25.32 (25.20) 25.52 (25.21) 25.32 (25.21) 25.12 (25.23) 25.52 (25.25) 25.32 (25.24) 25.32 (25.21) 25.52 (25.23) 25.12 (25.23) 25.32 (25.24) 25.32 (25.19) 24.91 (25.23) 25.32 (25.24) 25.32 (25.24) 25.32 (25.23) 25.32 (25.24) 25.32 (25.24) 25.52 (25.21) 25.32 (25.23) 25.32 (25.21) 25.32 (25.24) 25.32 (25.22) 25.32 (25.21) 25.12 (25.23)
Results for source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt:
| 39% 64C P2 132W / 250W | 1381MiB / 11018MiB | 44% Default |
| 0 4608 C deepstream-app 1186MiB |
**PERF: 188.96 (190.24) 188.96 (190.24) 188.96 (190.24) 188.96 (190.24)
**PERF: 188.77 (190.11) 188.77 (190.11) 188.77 (190.11) 188.77 (190.11)
**PERF: 189.63 (190.08) 189.63 (190.08) 189.63 (190.08) 189.63 (190.08)
**PERF: 188.70 (189.96) 188.70 (189.96) 188.70 (189.96) 188.70 (189.96)
**PERF: 189.11 (189.91) 189.11 (189.91) 189.11 (189.91) 189.11 (189.91)
**PERF: 189.75 (189.90) 189.75 (189.90) 189.75 (189.90) 189.75 (189.90)
**PERF: 188.26 (189.79) 188.26 (189.79) 188.26 (189.79) 188.26 (189.79)
