[GStreamer][Python] Problem with writing using subprocess
I’m trying to stream an RTSP feed using GStreamer.
 Input : IP camera (RTSP, H.264, 1920*1080)
            - `cv2.VideoCapture()`
 Write : RTSP (H.264, 1920*1080)
            - in `while` loop
               - `subprocess.stdin.write(GStreamer pipeline)`
I want to send frames to the MediaMTX RTSP server using a GStreamer pipeline.
The imshow function is functioning correctly.
But, the ‘write’ function isn’t functioning correctly. It doesn’t work at all
After attempting to connect to the RTSP stream from another machine, the MediaMTX terminal displayed the following message:
Here is the code
import cv2
import subprocess as sp
import psutil
RTSP_URL = {RTSP_source}
RTSP_SERVER_URL = 'rtsp://localhost:8554/mystream'
pipeline_out = (
    f'gst-launch-1.0 fdsrc  ! queue2 !'
    f'h264parse ! nvv4l2decoder !'
    f'nvvidconv ! '
    f'"video/x-raw(memory:NVMM), format=(string)I420" ! '
    f'nvv4l2h264enc bitrate=4000000 ! '
    f'rtspclientsink location={RTSP_SERVER_URL}'
p_out = sp.Popen(pipeline_out, shell=True, stdin=sp.PIPE, bufsize=10**9)
if __name__=='__main__':
    try:
        cap = cv2.VideoCapture(RTSP_URL)
        i = 0
        while True:
            ret, frame = cap.read()
            if not ret:
                print("Failed to read from stream")
                cap.release()
                break
            frame_yuv = cv2.cvtColor(frame, cv2.COLOR_BGR2YUV_I420)
            ##### Here is the problem #####
            p_out.stdin.write(frame_yuv.tobytes())
            p_out.stdin.flush()  # Flush the buffer
            # Print memory usage
            process = psutil.Process()  # Get the current process
            memory_usage = process.memory_info().rss  # Get the memory usage in bytes
            print(f"Memory usage: {memory_usage} bytes")
            print(f"### {i} ###")
            cv2.imshow("RTSP", frame)
            i = i + 1
            if cv2.waitKey(1) & 0xFF == ord('q'):
                break
    except KeyboardInterrupt:
        pass
    except Exception as e:
        print(f"An error occured : {e}")
    finally:
        cap.release()
        cv2.destroyAllWindows()
        if p_out.poll() is None:
            p_out.stdin.close()
            p_out.wait()
            p_out.kill()```
For RTSP output, there is a sample in DeepStream SDK:
https://github.com/NVIDIA-AI-IOT/deepstream_python_apps/tree/master/apps/deepstream-test1-rtsp-out
Please take a look. Since you don’t use DeepStream SDK, you may skip it and check the part of setting up RTSP.
