We are trying to run our c++ code on orin (it was working well on tx2) that create the following pipeline :
filesrc location="" ! qtdemux ! h264parse ! nvv4l2decoder ! nvvidconv ! video/x-raw,format=UYVY ! appsink.
We do not create a main loop and leave the pipeline in PAUSED state in order to manipulate it frame by frame thanks to gst_app_sink_try_pull_preroll and seeks.
However on orin, we are stuck on the seeking function that appears to be in an deadlock state :
GstEvent* event = gst_event_new_seek(1.0,
GST_FORMAT_TIME,
static_cast<GstSeekFlags>(GST_SEEK_FLAG_FLUSH | GST_SEEK_FLAG_ACCURATE),
GST_SEEK_TYPE_SET,
frame * static_cast<gint64>(Camera::FRAME_DURATION.MicroSeconds()) * 1000,
GST_SEEK_TYPE_NONE,
0);
gst_element_send_event(pipeline_.get(), event);
gst_element_send_event never return.
Thank you for your help !
• DeepStream Version
• TensorRT Version
Orin 32Go 8cpu
none
r35 2.1
• TensorRT Version
libnvinfer8 8.5.2-1+cuda11.4
iGPU (nvidia-l4t-cuda, 35.2.1-20230124153320)
bugs
I will try to write a small sample reproducing the issue.
JetPack r35.2.1 only support TensorRT 7.1.3. How could you get the TensorRT 8.5.2 installed?
libnvinfer8 is on the nvidia depository
apt-cache madison libnvinfer8
libnvinfer8 | 8.5.2-1+cuda11.4 | https://repo.download.nvidia.com/jetson/common r35.2/main arm64 Packages
apt-cache madison tensorrt
tensorrt | 8.5.2.2-1+cuda11.4 | https://repo.download.nvidia.com/jetson/common r35.2/main arm64 Packages
We have something else thats not working and may be strongly be linked to this problem :
auto const [framerate_num, framerate_den] = [&]() -> std::pair<int64_t, int64_t> {
if (auto const caps = GetElement(element_name).GetCaps(); caps && GST_IS_CAPS(caps.get())) {
if (GstStructure const* structure = gst_caps_get_structure(caps.get(), 0); structure) {
if (GValue const* framerate = gst_structure_get_value(structure, "framerate"); framerate) {
if (G_VALUE_TYPE(framerate) == GST_TYPE_FRACTION_RANGE) {
framerate = gst_value_get_fraction_range_min(framerate);
if (framerate) {
return {gst_value_get_fraction_numerator(framerate), gst_value_get_fraction_denominator(framerate)};
return {};
Always return {0,1}
alexandre.garcin:
Can you confirm the JetPack version is r35.2.1?
alexandre.garcin:
if (framerate) {
return {};
What is the element? How can we know what is happening with just a piece of code? Can you provide a simple instruction of duplicating this issue in our Jetson device?
Yes
head -1 /etc/nv_tegra_release
R35 (release), REVISION: 2.1, GCID: 32413640, BOARD: t186ref, EABI: aarch64, DATE: Tue Jan 24 23:38:33 UTC 2023
You can find here a sample of code that is reproducing the issue.
The Deadlock doesn’t happens always but most of the time.
I have linked as well a test video that was triggering it.
CMakeLists.txt (1.3 KB)
main.cpp (13.1 KB)
main.hpp (2.6 KB)
Since there is no appsink sample consumer implementation in your code, can you use the following pipeline instead?
gst-launch-1.0 filesrc location=xxx.mp4 ! qtdemux ! h264parse ! nvv4l2decoder ! nvvidconv ! video/x-raw,format=UYVY ! appsink drop=TRUE max-buffers=2 enable-last-sample=FALSE wait-on-eos=FALSE
Thank you for your answer,
by applying what you are suggesting
--- a/main.cpp
+++ b/main.cpp
@@ -300,6 +300,10 @@ int main(int argc, char * argv[]) {
r_source.SetProperty("location", argv[1]);
Element *p_output_ = &pipeline_.Add("appsink", "video-output");
+ p_output_->SetProperty("drop", true);
+ p_output_->SetProperty("max-buffers", 2);
+ p_output_->SetProperty("enable-last-sample", false);
+ p_output_->SetProperty("wait-on-eos", false);
// clang-format off
p_output_->SetProperty("caps", gst_caps_new_simple(
I still get the deadlock :
Opening in BLOCKING MODE
Dynamic pad created, linking demuxer/decoder
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
(gstreamer_deadlock:95924): GLib-GObject-CRITICAL **: 16:41:44.979: g_object_unref: assertion ‘G_IS_OBJECT (object)’ failed
INVALID framerate_num HERE : 0, 1
DEADLOCK HERE
FYI : I did not share our consumer implementation because this part of code is never reached (due to the deadlock) that doesn’t make it pertinent for your investigation.
Thank you
Please check this sample and give it a try:
Deadlock when try to seek in pipeline
What do you mean by “this sample”, that simple :
filesrc location=video.mkv ! matroskademux name=demuxer demuxer.video_0 ! identity name=tmp ! nvv4l2decoder ! nvvidconv ! video/x-raw ! appsink name=sink emit-signals=true sync=false
thank you.
The user shares a sample seek_bug_min_ex.zip and we can run it without hitting deadlock. Would suggest you give it a try.
Unfortunatly, I cant generate the video.mkv from this sample.
As mentioned by you on this thread: Video encoder nvv4l2vp9enc in Orin - #3 by DaneLLL , vp9encodding is not supported.
Could you please give me a sample so I can try this ?
You can modify the samplle to test h264 or h265.
In generate_video.sh , please change the pipeline to
gst-launch-1.0 videotestsrc num-buffers=4500 ! video/x-raw, format=BGR, width=1920, height=1080, framerate=15/1 ! videoconvert ! nvvidconv ! "video/x-raw(memory:NVMM), format=NV12" ! nvv4l2h264 maxperf-enable=1 control-rate=0 bitrate=8000000 ! h264parse ! matroskamux ! filesink location=video.mkv
And run the pipeline in test sample:
std::string seek_pipeline =
"filesrc location=" + video_file + " ! "
"matroskademux name=demuxer demuxer.video_0 ! "
"h264parse ! nvv4l2decoder ! "
"nvvidconv ! "
"video/x-raw ! "
"appsink name=sink emit-signals=true sync=false";
DaneLLL:
matroskademux
With your simple I couldn’t reproduce the deadlock,
However, by applying the following patch on main.cpp :
diff -u main.cpp ../seek_bug_min_ex_/main.cpp
--- main.cpp 2021-07-28 17:09:43.000000000 +0200
+++ ../seek_bug_min_ex_/main.cpp 2023-03-27 17:43:05.874309635 +0200
@@ -7,6 +7,7 @@
#include <mutex>
#include <thread>
std::atomic_bool done{false};
void done_handler(int) { done = true; }
@@ -65,10 +66,10 @@
// clang-format off
- "matroskademux name=demuxer demuxer.video_0 ! "
- "nvv4l2decoder ! "
+ "qtdemux ! "
+ "h264parse ! nvv4l2decoder ! "
"nvvidconv ! "
- "video/x-raw ! "
+ "video/x-raw,format=UYVY ! "
// clang-format on
@@ -111,6 +112,22 @@
gst_message_unref(msg);
+ auto sink = gst_bin_get_by_name(GST_BIN(pipeline), "sink");
+ auto pad = gst_element_get_static_pad (sink, "sink");
+ auto caps = gst_pad_get_current_caps(pad);
+ if (caps && GST_IS_CAPS(caps)) {
+ GstStructure const *structure = gst_caps_get_structure(caps, 0);
+ GValue const *framerate = gst_structure_get_value(structure, "framerate");
+ if (G_VALUE_TYPE(framerate) == GST_TYPE_FRACTION_RANGE) {
+ framerate = gst_value_get_fraction_range_min(framerate);
+ std::cout << "framerate : " << gst_value_get_fraction_numerator(framerate) << " " << gst_value_get_fraction_denominator(framerate) << std::endl;
+ gst_object_unref(pad);
+ gst_caps_unref (caps);
std::cout << "start seek" << std::endl;
// FIXME freezing here
bool seek_result = gst_element_seek_simple(
For floating point framerate (15.02), I stil get a wrong framerate number : 0/1.
EDIT : By adding a sleep of 100ms just before the seek, We also get the deadlock with your sample (with both : an integral framerate of 15fps and a video of15.02fps).
diff -u seek_bug_min_ex/main.cpp seek_bug_min_ex_/main.cpp
--- seek_bug_min_ex/main.cpp 2023-03-27 18:18:32.471061893 +0200
+++ seek_bug_min_ex_/main.cpp 2023-03-27 18:26:09.570088425 +0200
@@ -111,7 +112,7 @@
+ std::this_thread::sleep_for(std::chrono::milliseconds{100});
Please check if you can share the video file. It seems like it is specific to the video file you are testing.
