GStreamer warning: Embedded video playback halted; module v4l2src7 reported: Failed to allocate required memory
I am trying to capture full resolution (3840x2160) images from my Spinel UC80MPD USB 2.0 camera on my Xavier NX and am experiencing some errors. Specifically, I’ve tried instantiating an OpenCV VideoCapture object in the following two ways:
cap = cv2.VideoCapture(0)
and
cap = cv2.VideoCapture('v4l2src device=/dev/video0 ! video/x-raw, width=(int)3840, height=(int)2160 ! videoconvert ! video/x-raw, format=(string)BGR ! appsink', cv2.CAP_GSTREAMER)
But, in both cases, I am encountering the following error messages:
[ WARN:0] global /home/nvidia/host/build_opencv/nv_opencv/modules/videoio/src/cap_gstreamer.cpp (1757) handleMessage OpenCV | GStreamer warning: Embedded video playback halted; module v4l2src7 reported: Failed to allocate required memory.
[ WARN:0] global /home/nvidia/host/build_opencv/nv_opencv/modules/videoio/src/cap_gstreamer.cpp (886) open OpenCV | GStreamer warning: unable to start pipeline
[ WARN:0] global /home/nvidia/host/build_opencv/nv_opencv/modules/videoio/src/cap_gstreamer.cpp (480) isPipelinePlaying OpenCV | GStreamer warning: GStreamer: pipeline have not been created
If I instantiate the VideoCapture object at a resolution (supported by the camera) that is lower than 1920x1080, there are no issues whatsoever. This is strange because on the same Xavier NX I am able to capture full resolution (3264x2448) images using a Spinel UC80MPA without issue.
I’ve tested instantiating a VideoCapture object on my laptop with this new camera and have not had any warnings or errors, and am able to capture full-resolution images.
Does anyone have any thoughts on what the issue here might be and what steps I can take to fix it?
Could you check if v4l2-ctl can capture 3264x2448?
Also does it YUV format? Can the gst-launch-1.0 v4l2src … working?
This camera can not capture 3264x2448 (that’s the other camera that is working as expected). See below for the list of supported resolutions and formats for the camera in question:
[video4linux2,v4l2 @ 0x55870a9600] Compressed:       mjpeg :          Motion-JPEG : 3840x2160 2592x1944 2048x1536 1600x1200 1920x1080 1280x960 1280x720 800x600 640x480 320x240
[video4linux2,v4l2 @ 0x55870a9600] Raw       :     yuyv422 :           YUYV 4:2:2 : 3840x2160 2592x1944 2048x1536 1600x1200 1920x1080 1280x960 1280x720 800x600 640x480 320x240
Could you elaborate on what gst-launch-1.0 command I should check?
I tried this command:
gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw, width=3840, height=2160 ! videoconvert ! video/x-raw, format=BGR ! nvoverlaysink
Which yielded the following error:
Setting pipeline to PAUSED ...        │··
Pipeline is live and does not need PREROLL ...        │··
Setting pipeline to PLAYING ...        │··
New clock: GstSystemClock        │··
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Failed to allocate required memory.        │··
Additional debug info:        │··
gstv4l2src.c(658): gst_v4l2src_decide_allocation (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:        │··
Buffer pool activation failed        │··
Execution ended after 0:00:00.104024708        │··
Setting pipeline to READY ...        │··
Setting pipeline to NULL ...        │··
Freeing pipeline ...
Same memory allocation error.
I was able to solve this problem by instantiating the video capture object in the following way:
cap = cv2.VideoCapture(f'v4l2src device=/dev/video0 io-mode=2 ! image/jpeg, width=(int)3840, height=(int)2160 !  nvjpegdec ! video/x-raw, format=I420 ! appsink', cv2.CAP_GSTREAMER)
Upon further research into the specs of the camera (by running v4l2-ctl --info -d /dev/video0 --list-formats-ext) I was able to determine that, when capturing raw frames at full resolution, the max supported frame rate is 1 FPS (see below):
        Index       : 1        │······
        Type        : Video Capture        │······
        Pixel Format: 'YUYV'        │······
        Name        : YUYV 4:2:2        │······
                Size: Discrete 3840x2160        │······
                        Interval: Discrete 1.000s (1.000 fps)        │······
                Size: Discrete 2592x1944        │······
                Size: Discrete 2048x1536        │······
                        Interval: Discrete 0.333s (3.000 fps)        │······
                Size: Discrete 1600x1200        │······
                        Interval: Discrete 0.200s (5.000 fps)        │······
                Size: Discrete 1920x1080        │······
                Size: Discrete 1280x960        │······
                Size: Discrete 1280x720        │······
                        Interval: Discrete 0.100s (10.000 fps)        │······
                Size: Discrete 800x600        │······
                        Interval: Discrete 0.050s (20.000 fps)        │······
                        Interval: Discrete 0.067s (15.000 fps)        │······
                Size: Discrete 640x480        │······
                        Interval: Discrete 0.033s (30.000 fps)        │······
                        Interval: Discrete 0.040s (25.000 fps)        │······
                Size: Discrete 320x240        │······
However, using MJPEG, it is possible to capture full resolution images at 30 FPS (see below):
        Index       : 0        │······
        Pixel Format: 'MJPG' (compressed)        │······
So, even if I solve the memory allocation error, I wouldn’t be able to capture frames at the required frame rate. As such, initializing the capture object with MJPEG solved the problem for me.
