hi,
the Gsync screen of the Alienware M18 R2 is not detected, I have the latest drivers 550.54.14.
Please run nvidia-bug-report.sh as root and attach the resulting nvidia-bug-report.log.gz file to your post.
nvidia-bug-report.log.gz (528.2 KB)
G-Sync compatible is detected by the driver but disabled:
[ 26.274454] nvidia-modeset: WARNING: GPU:0: BOE Technology Group Co., Ltd (DP-0): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
Don’t really know why, the decoded EDID looks fine:
edid-decode (hex):
00 ff ff ff ff ff ff 00 09 e5 fb 0a 00 00 00 00
1d 20 01 04 a5 27 18 78 03 e5 f5 ae 50 44 b1 24
0e 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 6b 6e 00 a0 a0 40 84 60 30 20
36 00 84 f2 10 00 00 1a 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 fe 00 48
46 31 46 56 80 4e 45 31 38 4e 5a 31 00 00 00 00
00 02 41 0f 9e 00 03 00 00 0f 41 0a 20 20 01 20
70 20 79 02 00 22 00 14 69 dc 0b 85 ff 09 9f 00
2f 00 1f 00 3f 06 83 00 02 00 05 00 25 00 09 69
dc 0b 69 dc 0b 3c a5 80 81 00 13 72 1a 00 00 03
01 3c a5 00 00 53 51 53 51 a5 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 75 90
Block 0, Base EDID:
EDID Structure Version & Revision: 1.4
Vendor & Product Identification:
Manufacturer: BOE
Model: 2811
Made in: week 29 of 2022
Basic Display Parameters & Features:
Digital display
Bits per primary color channel: 8
DisplayPort interface
Maximum image size: 39 cm x 24 cm
Gamma: 2.20
Supported color formats: RGB 4:4:4
First detailed timing includes the native pixel format and preferred refresh rate
Display is continuous frequency
Color Characteristics:
Red : 0.6826, 0.3144
Green: 0.2666, 0.6923
Blue : 0.1435, 0.0576
White: 0.3134, 0.3291
Established Timings I & II: none
Standard Timings: none
Detailed Timing Descriptors:
DTD 1: 2560x1600 60.001613 Hz 8:5 103.923 kHz 282.670000 MHz (388 mm x 242 mm)
Hfront 48 Hsync 32 Hback 80 Hpol P
Vfront 3 Vsync 6 Vback 123 Vpol N
Empty Descriptor
Alphanumeric Data String: 'HF1FV'
Manufacturer-Specified Display Descriptor (0x00): 00 00 00 02 41 0f 9e 00 03 00 00 0f 41 0a 20 20 '....A.......A. '
Extension blocks: 1
Checksum: 0x20
Block 1, DisplayID Extension Block:
Version: 2.0
Extension Count: 0
Display Product Primary Use Case: None of the listed primary use cases; generic display
Video Timing Modes Type 7 - Detailed Timings Data Block:
DTD: 2560x1600 165.000085 Hz 16:10 285.780 kHz 777.322000 MHz (aspect 16:10, no 3D stereo, preferred)
Hfront 48 Hsync 32 Hback 80 Hpol N
Dynamic Video Timing Range Limits Data Block:
Minimum Pixel Clock: 777322 kHz
Maximum Pixel Clock: 777322 kHz
Minimum Vertical Refresh Rate: 60 Hz
Maximum Vertical Refresh Rate: 165 Hz
Seamless Dynamic Video Timing Support: Yes
CTA-861 DisplayID Data Block:
Vendor-Specific Data Block (AMD), OUI 00-00-1A:
Version: 3.1
Minimum Refresh Rate: 60 Hz
Maximum Refresh Rate: 165 Hz
Flags 1.x: 0x00
Flags 2.x: 0x00
Maximum luminance: 83 (301.833 cd/m^2)
Minimum luminance: 81 (0.305 cd/m^2)
Unknown: 0x53 0x51
Checksum: 0x75
Checksum: 0x90
IDK too, i try Fedora, Arch… Same bug. Maybe someone know a workaround ?
When my computer start : [ 1875.586129] nvidia-modeset : WARNING: GPU:0: BOE Technologie Group Co., Ltd (DP-0): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
I wonder if this is related to this recent issue?
All I can say is that I’ve tested several drivers, 535, 545, and 550. I’ve also tried several distributions, Ubuntu, Fedora, Arch, and it doesn’t seem to work. In light of my tests, I don’t think it’s due to a recent issue, I believe this PC has never been properly supported.
I wonder whether this changes when disabling Advanced Optimus in BIOS for this laptop?
No. Optimus or Nvidia Only it’s the same
nvidia-bug-report.log.gz (809.2 KB)
Nvidia driver: 555.58.02. G-Sync is always broken with my 4090 mobile. I have tested multiple distros on both Wayland and X11.
I have the same problem on my Alienware m16 R1 4090 mobile. Have tried multiple drivers including the latest 555.58.02. Not working in Wayland or X11.
drm_info shows both “vrr_capable” = 0 and “VRR_ENABLED” = 0 and X Server Settings shows: G-SYNC Mode Available: None and G-SYNC Mode Enabled: No
I’m thinking perhaps the EDID is not being parsed correctly by the driver? In Windows the display is correctly detected as “G-Sync Capable”.
EDID and bug report attached.
nvidia-bug-report.log.gz (2.7 MB)
edid.zip (335 Bytes)
I came across a similar issue with a different laptop that was due to the EDID not reporting VRR in both blocks. Looking at delor.vd’s EDID and mine, it seems to be the same problem I think?
UPDATE:
The 560 beta driver appears to have resolved this for me in both Wayland and X11. I haven’t had a chance to fully test just yet, but at least it’s detecting the display as G-Sync/VRR capable now.
A heartfelt thank you to the driver team, this was the last hurdle before making the switch to Linux full-time!
