GT 640 driver 470.182.03 not is possible read display EDID
Hello.
Ubuntu 20.04.6 Geforce GT 640 using 470.182.03 in an display LCD vga cable.
In Nvidia X Server Settings is showed the monitor display is an CRT and not read the EDID data from display.
I need manually configure to use 96 dpi.
However in same machine and same OS if using only the IGP Radeon HD 3000 is possible read the display EDID data.
Have any way to fix it ?
Have an nice week.
If the edid can’t be read, usually either the cable or the monitor is broken. Are you sure the radeon can read the edid or does it just allow higher resolutions per default?
Please check
xrandr --verbose
when using the radeon whether the edid is displayed.
using xrandr --verbose
Note … I had selected 1368x768 in Nvidia settings
After I post the command using the IGP Radeon
Screen 0: minimum 8 x 8, current 1368 x 768, maximum 16384 x 16384
VGA-0 connected primary 1368x768+0+0 (0x284) normal (normal left inverted right x axis y axis) 0mm x 0mm
Identifier: 0x27d
Timestamp: 36523
Subpixel: unknown
Gamma: 0.33:1.0:2.3
Brightness: 0.63
Clones:
CRTC: 0
CRTCs: 0 1 2 3
Transform: 1.000000 0.000000 0.000000
0.000000 1.000000 0.000000
0.000000 0.000000 1.000000
filter:
CTM: 0 1 0 0 0 0 0 0 0 1 0 0 0 0 0 0
0 1
CscMatrix: 65536 0 0 0 0 65536 0 0 0 0 65536 0
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
SignalFormat: VGA
supported: VGA
ConnectorType: VGA
ConnectorNumber: 2
_ConnectorLocation: 2
non-desktop: 0
supported: 0, 1
1024x768 (0x27e) 78.750MHz +HSync +VSync +preferred
h: width 1024 start 1040 end 1136 total 1312 skew 0 clock 60.02KHz
v: height 768 start 769 end 772 total 800 clock 75.03Hz
1600x900 (0x27f) 118.250MHz -HSync +VSync
h: width 1600 start 1696 end 1856 total 2112 skew 0 clock 55.99KHz
v: height 900 start 903 end 908 total 934 clock 59.95Hz
1600x900 (0x280) 97.500MHz +HSync -VSync
h: width 1600 start 1648 end 1680 total 1760 skew 0 clock 55.40KHz
v: height 900 start 903 end 908 total 926 clock 59.82Hz
1440x900 (0x281) 106.500MHz -HSync +VSync
h: width 1440 start 1520 end 1672 total 1904 skew 0 clock 55.93KHz
v: height 900 start 903 end 909 total 934 clock 59.89Hz
1400x900 (0x282) 103.500MHz -HSync +VSync
h: width 1400 start 1480 end 1624 total 1848 skew 0 clock 56.01KHz
v: height 900 start 903 end 913 total 934 clock 59.96Hz
1400x900 (0x283) 86.500MHz +HSync -VSync
h: width 1400 start 1448 end 1480 total 1560 skew 0 clock 55.45KHz
v: height 900 start 903 end 913 total 926 clock 59.88Hz
1368x768 (0x284) 85.250MHz -HSync +VSync *current
h: width 1368 start 1440 end 1576 total 1784 skew 0 clock 47.79KHz
v: height 768 start 771 end 781 total 798 clock 59.88Hz
1368x768 (0x285) 72.250MHz +HSync -VSync
h: width 1368 start 1416 end 1448 total 1528 skew 0 clock 47.28KHz
v: height 768 start 771 end 781 total 790 clock 59.85Hz
1360x768 (0x286) 72.000MHz +HSync -VSync
h: width 1360 start 1408 end 1440 total 1520 skew 0 clock 47.37KHz
v: height 768 start 771 end 781 total 790 clock 59.96Hz
1360x768 (0x287) 84.750MHz -HSync +VSync
h: width 1360 start 1432 end 1568 total 1776 skew 0 clock 47.72KHz
v: height 768 start 771 end 781 total 798 clock 59.80Hz
1280x960 (0x288) 108.000MHz +HSync +VSync
h: width 1280 start 1376 end 1488 total 1800 skew 0 clock 60.00KHz
v: height 960 start 961 end 964 total 1000 clock 60.00Hz
1280x800 (0x289) 71.000MHz +HSync -VSync
h: width 1280 start 1328 end 1360 total 1440 skew 0 clock 49.31KHz
v: height 800 start 803 end 809 total 823 clock 59.91Hz
1280x800 (0x28a) 83.500MHz -HSync +VSync
h: width 1280 start 1352 end 1480 total 1680 skew 0 clock 49.70KHz
v: height 800 start 803 end 809 total 831 clock 59.81Hz
1280x720 (0x28b) 74.500MHz -HSync +VSync
h: width 1280 start 1344 end 1472 total 1664 skew 0 clock 44.77KHz
v: height 720 start 723 end 728 total 748 clock 59.86Hz
1280x720 (0x28c) 63.750MHz +HSync -VSync
h: width 1280 start 1328 end 1360 total 1440 skew 0 clock 44.27KHz
v: height 720 start 723 end 728 total 741 clock 59.74Hz
1152x864 (0x28d) 81.620MHz -HSync +VSync
h: width 1152 start 1216 end 1336 total 1520 skew 0 clock 53.70KHz
v: height 864 start 865 end 868 total 895 clock 60.00Hz
1024x768 (0x28e) 75.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1328 skew 0 clock 56.48KHz
v: height 768 start 771 end 777 total 806 clock 70.07Hz
1024x768 (0x28f) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
1024x576 (0x290) 46.500MHz -HSync +VSync
h: width 1024 start 1064 end 1160 total 1296 skew 0 clock 35.88KHz
v: height 576 start 579 end 584 total 599 clock 59.90Hz
1024x576 (0x291) 42.000MHz +HSync -VSync
h: width 1024 start 1072 end 1104 total 1184 skew 0 clock 35.47KHz
v: height 576 start 579 end 584 total 593 clock 59.82Hz
960x540 (0x292) 37.250MHz +HSync -VSync
h: width 960 start 1008 end 1040 total 1120 skew 0 clock 33.26KHz
v: height 540 start 543 end 548 total 556 clock 59.82Hz
960x540 (0x293) 40.750MHz -HSync +VSync
h: width 960 start 992 end 1088 total 1216 skew 0 clock 33.51KHz
v: height 540 start 543 end 548 total 562 clock 59.63Hz
864x486 (0x294) 32.500MHz -HSync +VSync
h: width 864 start 888 end 968 total 1072 skew 0 clock 30.32KHz
v: height 486 start 489 end 494 total 506 clock 59.92Hz
864x486 (0x295) 30.500MHz +HSync -VSync
h: width 864 start 912 end 944 total 1024 skew 0 clock 29.79KHz
v: height 486 start 489 end 494 total 500 clock 59.57Hz
832x624 (0x296) 57.284MHz -HSync -VSync
h: width 832 start 864 end 928 total 1152 skew 0 clock 49.73KHz
v: height 624 start 625 end 628 total 667 clock 74.55Hz
800x600 (0x297) 49.500MHz +HSync +VSync
h: width 800 start 816 end 896 total 1056 skew 0 clock 46.88KHz
v: height 600 start 601 end 604 total 625 clock 75.00Hz
800x600 (0x298) 50.000MHz +HSync +VSync
h: width 800 start 856 end 976 total 1040 skew 0 clock 48.08KHz
v: height 600 start 637 end 643 total 666 clock 72.19Hz
800x600 (0x299) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
800x600 (0x29a) 36.000MHz +HSync +VSync
h: width 800 start 824 end 896 total 1024 skew 0 clock 35.16KHz
v: height 600 start 601 end 603 total 625 clock 56.25Hz
800x450 (0x29b) 59.125MHz -HSync +VSync DoubleScan
h: width 800 start 848 end 928 total 1056 skew 0 clock 55.99KHz
v: height 450 start 451 end 454 total 467 clock 59.95Hz
800x450 (0x29c) 48.750MHz +HSync -VSync DoubleScan
h: width 800 start 824 end 840 total 880 skew 0 clock 55.40KHz
v: height 450 start 451 end 454 total 463 clock 59.82Hz
720x450 (0x29d) 53.250MHz -HSync +VSync DoubleScan
h: width 720 start 760 end 836 total 952 skew 0 clock 55.93KHz
v: height 450 start 451 end 454 total 467 clock 59.89Hz
700x450 (0x29e) 51.750MHz -HSync +VSync DoubleScan
h: width 700 start 740 end 812 total 924 skew 0 clock 56.01KHz
v: height 450 start 451 end 456 total 467 clock 59.96Hz
700x450 (0x29f) 43.250MHz +HSync -VSync DoubleScan
h: width 700 start 724 end 740 total 780 skew 0 clock 55.45KHz
v: height 450 start 451 end 456 total 463 clock 59.88Hz
684x384 (0x2a0) 42.625MHz -HSync +VSync DoubleScan
h: width 684 start 720 end 788 total 892 skew 0 clock 47.79KHz
v: height 384 start 385 end 390 total 399 clock 59.88Hz
684x384 (0x2a1) 36.125MHz +HSync -VSync DoubleScan
h: width 684 start 708 end 724 total 764 skew 0 clock 47.28KHz
v: height 384 start 385 end 390 total 395 clock 59.85Hz
680x384 (0x2a2) 36.000MHz +HSync -VSync DoubleScan
h: width 680 start 704 end 720 total 760 skew 0 clock 47.37KHz
v: height 384 start 385 end 390 total 395 clock 59.96Hz
680x384 (0x2a3) 42.375MHz -HSync +VSync DoubleScan
h: width 680 start 716 end 784 total 888 skew 0 clock 47.72KHz
v: height 384 start 385 end 390 total 399 clock 59.80Hz
640x480 (0x2a4) 31.500MHz -HSync -VSync
h: width 640 start 656 end 720 total 840 skew 0 clock 37.50KHz
v: height 480 start 481 end 484 total 500 clock 75.00Hz
640x480 (0x2a5) 31.500MHz -HSync -VSync
h: width 640 start 664 end 704 total 832 skew 0 clock 37.86KHz
v: height 480 start 489 end 492 total 520 clock 72.81Hz
640x480 (0x2a6) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
640x400 (0x2a7) 35.500MHz +HSync -VSync DoubleScan
h: width 640 start 664 end 680 total 720 skew 0 clock 49.31KHz
v: height 400 start 401 end 404 total 411 clock 59.98Hz
640x400 (0x2a8) 41.750MHz -HSync +VSync DoubleScan
h: width 640 start 676 end 740 total 840 skew 0 clock 49.70KHz
v: height 400 start 401 end 404 total 415 clock 59.88Hz
640x360 (0x2a9) 37.250MHz -HSync +VSync DoubleScan
h: width 640 start 672 end 736 total 832 skew 0 clock 44.77KHz
v: height 360 start 361 end 364 total 374 clock 59.86Hz
640x360 (0x2aa) 31.875MHz +HSync -VSync DoubleScan
h: width 640 start 664 end 680 total 720 skew 0 clock 44.27KHz
v: height 360 start 361 end 364 total 370 clock 59.83Hz
512x384 (0x2ab) 37.500MHz -HSync -VSync DoubleScan
h: width 512 start 524 end 592 total 664 skew 0 clock 56.48KHz
v: height 384 start 385 end 388 total 403 clock 70.07Hz
512x384 (0x2ac) 32.500MHz -HSync -VSync DoubleScan
h: width 512 start 524 end 592 total 672 skew 0 clock 48.36KHz
v: height 384 start 385 end 388 total 403 clock 60.00Hz
512x288 (0x2ad) 23.250MHz -HSync +VSync DoubleScan
h: width 512 start 532 end 580 total 648 skew 0 clock 35.88KHz
v: height 288 start 289 end 292 total 299 clock 60.00Hz
512x288 (0x2ae) 21.000MHz +HSync -VSync DoubleScan
h: width 512 start 536 end 552 total 592 skew 0 clock 35.47KHz
v: height 288 start 289 end 292 total 296 clock 59.92Hz
480x270 (0x2af) 18.625MHz +HSync -VSync DoubleScan
h: width 480 start 504 end 520 total 560 skew 0 clock 33.26KHz
v: height 270 start 271 end 274 total 278 clock 59.82Hz
480x270 (0x2b0) 20.375MHz -HSync +VSync DoubleScan
h: width 480 start 496 end 544 total 608 skew 0 clock 33.51KHz
v: height 270 start 271 end 274 total 281 clock 59.63Hz
432x243 (0x2b1) 16.250MHz -HSync +VSync DoubleScan
h: width 432 start 444 end 484 total 536 skew 0 clock 30.32KHz
v: height 243 start 244 end 247 total 253 clock 59.92Hz
432x243 (0x2b2) 15.250MHz +HSync -VSync DoubleScan
h: width 432 start 456 end 472 total 512 skew 0 clock 29.79KHz
v: height 243 start 244 end 247 total 250 clock 59.57Hz
400x300 (0x2b3) 25.000MHz +HSync +VSync DoubleScan
h: width 400 start 428 end 488 total 520 skew 0 clock 48.08KHz
v: height 300 start 318 end 321 total 333 clock 72.19Hz
320x240 (0x2b4) 15.750MHz -HSync -VSync DoubleScan
h: width 320 start 332 end 352 total 416 skew 0 clock 37.86KHz
v: height 240 start 244 end 246 total 260 clock 72.81Hz
320x240 (0x2b5) 12.587MHz -HSync -VSync DoubleScan
h: width 320 start 328 end 376 total 400 skew 0 clock 31.47KHz
v: height 240 start 245 end 246 total 262 clock 60.05Hz
DVI-D-0 disconnected (normal left inverted right x axis y axis)
Identifier: 0x2b6
Timestamp: 36523
Subpixel: unknown
Clones:
CRTCs: 0 1 2 3
filter:
0 1
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
SignalFormat: TMDS
supported: TMDS
ConnectorType: DVI-D
ConnectorNumber: 0
_ConnectorLocation: 0
non-desktop: 0
supported: 0, 1
HDMI-0 disconnected (normal left inverted right x axis y axis)
Identifier: 0x2b7
Timestamp: 36523
Subpixel: unknown
Clones:
CRTCs: 0 1 2 3
filter:
0 1
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
SignalFormat: TMDS
supported: TMDS
ConnectorType: HDMI
ConnectorNumber: 1
_ConnectorLocation: 1
non-desktop: 0
supported: 0, 1
The edid can’t be read as well on the radeon, it’s just that the amdgpu/nouveau driver default to higher resolutions in that case.
Please check/replace your cable, if that yield nothing, you’ll either have to create an xorg.conf setting HorizSync/VertRefresh values manually or attach a fake edid using the CustomEDID option.
Thanks for replying.
Not problem in monitor or cable.
I have enabled the IGP Radeon and done an test doing the command
xrandr --verbose
showing the message
Screen 0: minimum 320 x 200, current 1366 x 768, maximum 8192 x 8192
VGA-0 connected primary 1366x768+0+0 (0x54) normal (normal left inverted right x axis y axis) 344mm x 194mm
Identifier: 0x51
Timestamp: 28721
Subpixel: no subpixels
Gamma: 1.0:1.7:3.0
Brightness: 1.0
Clones:
CRTC: 0
CRTCs: 0 1
filter:
EDID:
00ffffffffffff001e6d3e8b01010101
0a15010368231478ead025a258559c28
0f5054a76a00314f454f614f01010101
010101010101662156aa51001e30468f
330058c21000001e000000fd00384b1e
3d09000a202020202020000000fc0045
313634310a20202020202020000000ff
000a202020202020202020202020004c
TearFree: auto
supported: off, on, auto
scaling mode: None
supported: None, Full, Center, Full aspect
load detection: 1
range: (0, 1)
link-status: Good
supported: Good, Bad
CONNECTOR_ID: 46
supported: 46
non-desktop: 0
range: (0, 1)
1366x768 (0x54) 85.500MHz +HSync +VSync *current +preferred
h: width 1366 start 1436 end 1579 total 1792 skew 0 clock 47.71KHz
v: height 768 start 771 end 774 total 798 clock 59.79Hz
1024x768 (0x55) 78.750MHz +HSync +VSync
1024x768 (0x56) 65.000MHz -HSync -VSync
832x624 (0x57) 57.284MHz -HSync -VSync
800x600 (0x58) 49.500MHz +HSync +VSync
800x600 (0x59) 40.000MHz +HSync +VSync
800x600 (0x5a) 36.000MHz +HSync +VSync
640x480 (0x5b) 31.500MHz -HSync -VSync
640x480 (0x5c) 25.175MHz -HSync -VSync
720x400 (0x5d) 28.320MHz -HSync +VSync
h: width 720 start 738 end 846 total 900 skew 0 clock 31.47KHz
v: height 400 start 412 end 414 total 449 clock 70.08Hz
Identifier: 0x52
Timestamp: 28721
Subpixel: horizontal rgb
Clones:
CRTCs: 0 1
filter:
TearFree: auto
audio: auto
scaling mode: None
dither: off
supported: off, on
underscan vborder: 0
range: (0, 128)
underscan hborder: 0
range: (0, 128)
underscan: off
coherent: 1
range: (0, 1)
link-status: Good
CONNECTOR_ID: 48
supported: 48
non-desktop: 0
range: (0, 1)
Strangely not is being possible read the LCD monitor EDID when using Geforce GT 640 and thus the video card use as being CRT.
How use an “fake” edid using the CustomEDID option using the EDID data from xrandr command done in Radeon ?
