Is the nVidia GT650M used in the new Macbook Pros a Kepler device? Or is it some older Fermi model.
Christian
Christian
Update: I found a table on an nVidia site which lists the device as being a Compute 3.0 part. Still if someone could post a deviceQuery for this chip, I’d be grateful.
Yes it seems to be Kepler,
“Based on the next-generation NVIDIA Kepler graphics architecture, the GeForce GT 650M offers unprecedented performance and extreme energy efficiency, giving it the muscle to process the 5,184,000 pixels in the next-gen MacBook Pro’s ultra high-resolution display. The GeForce GT 650M is not only up to the task, it maximizes power efficiency along the way.”
http://benchmarkreviews.com/index.php?option=com_content&task=view&id=19066&Itemid=99999999
Found 1 CUDA Capable device(s)
Device 0: "GeForce GT 650M"
CUDA Driver Version / Runtime Version 4.2 / 4.2
CUDA Capability Major/Minor version number: 3.0
Total amount of global memory: 2048 MBytes (2147483648 bytes)
( 2) Multiprocessors x (192) CUDA Cores/MP: 384 CUDA Cores
GPU Clock rate: 405 MHz (0.41 GHz)
Memory Clock rate: 2000 Mhz
Memory Bus Width: 128-bit
L2 Cache Size: 524288 bytes
Max Texture Dimension Size (x,y,z) 1D=(65536), 2D=(65536,65536), 3
D=(4096,4096,4096)
Max Layered Texture Size (dim) x layers 1D=(16384) x 2048, 2D=(16384,16
384) x 2048
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 2048
Maximum number of threads per block: 1024
Maximum sizes of each dimension of a block: 1024 x 1024 x 64
Maximum sizes of each dimension of a grid: 2147483647 x 65535 x 65535
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and execution: Yes with 1 copy engine(s)
Run time limit on kernels: Yes
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Concurrent kernel execution: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support enabled: No
Device is using TCC driver mode: No
Device supports Unified Addressing (UVA): No
Device PCI Bus ID / PCI location ID: 1 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simu
ltaneously) >
Thanks! We are considering shipping our simulation environment on a laptop with this GPU, however what worries me is the narrow 128 bit memory interface. I am concerned about the achievable memory bandwidth and whether it would be limiting to our application.
No problem
Here is a recent forum post where I achieve 76% utilization on this laptop : http://forums.nvidia.com/index.php?showtopic=230974
It seems to be generally a bit harder to achieve a high bandwidth utilization on Kepler compared to Fermi, I also attribute this to the thin memory interfaces.
