I have an IMU that transmits packets when an edge triggered interrupt is received from a GPIO pin. I am trying to accurately time when those interrupts are transmitted by my Jetson Orin Nano devkit using the Generic Timestamping Engine. For this to work I believe there are two things I have to do:
- Enable GTE
- Configure AON GPIO pins
I am currently struggling with the first item in that list. I have done the following so far:
- Update
tegra234-p3767-0000-p3768-0000-a0.dtsto be what is shown below:
/dts-v1/;
#include "tegra234-dcb-p3767-0000-dp.dtsi"
#include <tegra234-soc/mods-simple-bus.dtsi>
#include <t234-common-cvm/tegra234-thermal.dtsi>
#include <t234-common-cvm/tegra234-cpuidle.dtsi>
#include <t234-common-cvm/tegra234-thermal-cooling.dtsi>
#include <t234-common-cvm/tegra234-thermal-userspace-alert.dtsi>
#include "cvm/tegra234-p3767-0000.dtsi"
#include "cvb/tegra234-p3768-0000-a0.dtsi"
nvidia,dtsfilename = __FILE__;
nvidia,dtbbuildtime = __DATE__, __TIME__;
compatible = "nvidia,p3768-0000+p3767-0000", "nvidia,p3767-0000", "nvidia,tegra234", "nvidia,tegra23x";
model = "NVIDIA Orin NX Developer Kit";
gte@3aa0000 {
status = "okay";
gte@c1e0000 {
status = "okay";
gpio@c2f0000 {
/delete-property/ use-timestamp;
- Set following options in kernel config:
CONFIG_TEGRA_GTE_TEST=m
CONFIG_TEGRA_HTS_GTE=y
- Build kernel image and device tree blob.
- Copy kernel image and .dtb to Jetson and update
/boot/extlinux/extlinux.confto use copied files - Reboot Jetson
The Jetson reboots successfully but I am unable to see /dev/gtechip0 and therefore unable to use the timestamping engine. The only thing I can think of doing is actually flashing the device tree and kernel image, but I’m not sure if that makes a difference.
With regards to the AON GPIO, I don’t believe any are enable by default from looking at pin diagrams. Are there any guides on how to do this. Will I need to generate new .dts files using the excel workbook?
