Timestamping GPIO
in L4T Development Guide there is a mention of GPIO timestamping feature:
https://docs.nvidia.com/jetson/l4t/index.html#page/Tegra%2520Linux%2520Driver%2520Package%2520Development%2520Guide%2Fsoftware_features_tx2_tx2i.html%23wwpID0E0EB0HA
How can it be accessed from Linux? My task is to have timestamp of rising (or/and falling) edge on TX2 GPI, the more precise the better. Pure software solution has its limitations, specifically high jitter, so I’m interested in hardware timestamping of GPIO interrupts.
@Ximea
Sorry to tell the timestamp is the interrupt time and the software not implement yet.
Is it possible to implement this feature ourselves based on GTE and IVC examples for SPE? It looks like it should work, but maybe I’m missing something. Main question though is timestamp conversion - how timestamp reported by GTE corresponds to time sources used by Linux kernel? Ideally I would like a way to convert it to real time clock used by Linux.
Its is possible to implement but one needs to know all the registers to be read for GTE block.
We will be providing SW support for GTE in next release.
Please note that GTE gives timestamp using TSC ( Time Stamps Counter @ 31.25Mhz) which is a free running counter. It starts as soon as system boots.
So, clock_get_time in kernel is TSC counter value minus the counter value when kernel starts executing in nano sec.
While system time is RTC time.
Hope this helps
Thank you for the answer, we will wait for next release then.
i compiled tegra194_gte.c in the kernel source tree for my tx2 board, but i found that i can not access the gte control register, read always return 0, and dmesg shows the following error:
CPU5: SError detected, daif=1c0, spsr=0x60000045, mpidr=80000103, esr=bf000000
ROC:CCE Machine Check Error:
why this happened, i just want to read/write an register
tegra194_gte.c is not compatible with TX2 and it is never tested on TX2 for that reason. However, you can refer TX2 technical reference manual to modify but NVIDIA does not provide support for the same. The error could be coming from the security register blocking access to that register space, check mobile_scr.cfg for that GTE instance and make sure CCPLEX have the access.
i tried, but the TRM is not clear enough. i can not find the right entry in the bct mobile_scr.cfg file. so i search the key word GTE, and change all of the entry contain GTE to 0. but this does not work. is there any way to help me to verify whether my config is right.
and i want to known, is there any way to known the actual address of an index in the mobile_scr.cfg, and where can i get the corresponding between get slice id and lic or gpio irq number
