Upgraded from GT430 (works fine) to GTX 1050 ti on Fedora 29 x86_64 and can’t find a driver that supports the card. Using 430.26 or 418.74, the ones suggested by the nvidia driver downloader for this card, I get:
NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:1c82)
NVRM: installed in this system is not supported by the
NVRM: NVIDIA 430.34 driver release.
NVRM: Please see 'Appendix A - Supported NVIDIA GPU Products'
NVRM: in this release's README, available on the operating system
NVRM: specific graphics driver download page at www.nvidia.com.
In Appendix A the ID looks correct for this card and it should be supported?
nvidia-bug-report.log.gz (43 KB)
The 340.107 driver does work with the GTX1050ti but the card is unrecognised.
Same driver works with the GT430 and does identify the card: NVIDIA(0): NVIDIA GPU GeForce GT 430 (GF108)
I think your “GTX 1050 Ti” is counterfeit. The error you got from the 430.26 release is a pretty telltale sign, and it looks like someone doctored a GeForce GTX 550 Ti or similar to make it look like a 1050. Whoever did it didn’t bother to change the PCI ID of the audio function:
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GP107 [GeForce GTX 1050 Ti] [10de:1c82] (rev a1)
01:00.1 Audio device [0403]: NVIDIA Corporation <b>GF116</b> High Definition Audio Controller [10de:0bee] (rev a1)
So this looks like a legacy Fermi card disguised as a newer Pascal one.
I would recommend returning the card if possible and finding a genuine GTX 1050 Ti somewhere else.
Yes… “If it looks too good to be true …”
I think I have same problem - seems like fake card. Old driver works, but not driver for GTX 1050 TI. Bought it on Jan 2019 on ebay from seller “hopesit”.
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GP107 [GeForce GTX 1050 Ti] [10de:1c82] (rev a1) (prog-if 00 [VGA controller])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 32
Region 0: Memory at f4000000 (32-bit, non-prefetchable)
Region 1: Memory at e0000000 (64-bit, prefetchable)
Region 3: Memory at e8000000 (64-bit, prefetchable)
Region 5: I/O ports at e000
[virtual] Expansion ROM at 000c0000 [disabled]
Capabilities: [60] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [68] MSI: Enable+ Count=1/1 Maskable- 64bit+
Address: 00000000fee04004 Data: 4026
Capabilities: [78] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s <4us, L1 <64us
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 75.000W
DevCtl: CorrErr- NonFatalErr- FatalErr- UnsupReq-
RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop+
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr- TransPend-
LnkCap: Port #0, Speed 5GT/s, Width x16, ASPM L0s L1, Exit Latency L0s <256ns, L1 <4us
ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp-
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk+
ExtSynch- ClockPM+ AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 5GT/s (ok), Width x16 (ok)
TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Not Supported, TimeoutDis+, LTR-, OBFF Not Supported
AtomicOpsCap: 32bit- 64bit- 128bitCAS-
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
AtomicOpsCtl: ReqEn-
LnkCtl2: Target Link Speed: 2.5GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
Capabilities: [b4] Vendor Specific Information: Len=14 <?>
Capabilities: [100 v1] Virtual Channel
Caps: LPEVC=0 RefClk=100ns PATEntryBits=1
Arb: Fixed- WRR32- WRR64- WRR128-
Ctrl: ArbSelect=Fixed
Status: InProgress-
VC0: Caps: PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
Arb: Fixed- WRR32- WRR64- WRR128- TWRR128- WRR256-
Ctrl: Enable+ ID=0 ArbSelect=Fixed TC/VC=01
Status: NegoPending- InProgress-
Capabilities: [128 v1] Power Budgeting <?>
Capabilities: [600 v1] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Kernel driver in use: nvidia
Kernel modules: nouveau, nvidia_drm, nvidia
It’s a pcie 2.0 device, so most likely fake. You can use
sudo lspci -d 10de:*
to have a look at the audio controller, too.
