Hi
Since last update on 28/10/2017 the nvidia driver stop to work. I’m using the driver from rpmfusion.
Already removed and installed again, but still not working.
nvidia-bug-report.log.gz (64.2 KB)
Hi
According to the logs it looks like no nvidia driver is installed at all, even the nouveau blacklist is not in place anymore. So it’s not failing, it just can’t be found. Since you’re able to run nvidia-bug-report.sh, the driver is obviously installed. Looks like a packaging error somehow. Maybe see where the files end up on reinstalling.
Thanks @generix for looking into the report.
I’ve been trying others things and as I was almost hopping to another more nvidia friendly distro, I decided to try upgrade to Fedora 27 beta.
At beginning it didn’t work but after update the system (dnf update) it start to work again.
update.txt (36.3 KB)
Looking at the update.txt you were missing the nvidia module for the running kernel before. This explains why it wasn’t found. Seems like F26 upgraded the kernel but didn’t provide a matching nvidia driver.
I tried to install Fedora 27 RC_6 on my laptop ASUS N580VD-FI038T.
I had to boot the Live Distro using low res 800x600.
This laptop has a dual graphic card Intel / Nvidia 1050.
I tried to install te plain nouveau driver, the closed source Nvidia driver (from Nvidia, rpmfusion and negativo17, I tried the Bumblebee - NVIDIA Optimus support for Linux, and I tried PRIME as well.
Simply no luck, it’s not working.
Any help is very appreciated!
Did someone succeed in configuring the 1050 card/Intel card properly? how?
Thank you in advance
If this is really an Optimus system you will first have to get the intel gpu working. For a start, please post the output of
lspci -v
lspci -v
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers (rev 05)
Subsystem: ASUSTeK Computer Inc. Device 1a10
Flags: bus master, fast devsel, latency 0
Capabilities:
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x16) (rev 05) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 122
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 0000e000-0000efff
Memory behind bridge: ee000000-ef0fffff
Prefetchable memory behind bridge: 00000000d0000000-00000000e1ffffff
Capabilities:
Kernel driver in use: pcieport
Kernel modules: shpchp
00:02.0 VGA compatible controller: Intel Corporation Device 591b (rev 04) (prog-if 00 [VGA controller])
Flags: bus master, fast devsel, latency 0, IRQ 255
Memory at ed000000 (64-bit, non-prefetchable)
Memory at c0000000 (64-bit, prefetchable)
I/O ports at f000
[virtual] Expansion ROM at 000c0000 [disabled]
Capabilities:
Kernel modules: i915
00:04.0 Signal processing controller: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem (rev 05)
Flags: fast devsel, IRQ 16
Memory at ef320000 (64-bit, non-prefetchable)
Capabilities:
Kernel driver in use: proc_thermal
Kernel modules: processor_thermal_device
00:14.0 USB controller: Intel Corporation Sunrise Point-H USB 3.0 xHCI Controller (rev 31) (prog-if 30 [XHCI])
Subsystem: ASUSTeK Computer Inc. Device 201f
Flags: bus master, medium devsel, latency 0, IRQ 127
Memory at ef310000 (64-bit, non-prefetchable)
Capabilities:
Kernel driver in use: xhci_hcd
00:14.2 Signal processing controller: Intel Corporation Sunrise Point-H Thermal subsystem (rev 31)
Flags: fast devsel, IRQ 18
Memory at ef33a000 (64-bit, non-prefetchable)
Capabilities:
Kernel driver in use: intel_pch_thermal
Kernel modules: intel_pch_thermal
00:15.0 Signal processing controller: Intel Corporation Sunrise Point-H Serial IO I2C Controller #0 (rev 31)
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at ef339000 (64-bit, non-prefetchable)
Capabilities:
Kernel driver in use: intel-lpss
Kernel modules: intel_lpss_pci
00:15.1 Signal processing controller: Intel Corporation Sunrise Point-H Serial IO I2C Controller #1 (rev 31)
Flags: bus master, fast devsel, latency 0, IRQ 17
Memory at ef338000 (64-bit, non-prefetchable)
Capabilities:
00:16.0 Communication controller: Intel Corporation Sunrise Point-H CSME HECI #1 (rev 31)
Flags: bus master, fast devsel, latency 0, IRQ 129
Memory at ef337000 (64-bit, non-prefetchable)
Capabilities:
Kernel driver in use: mei_me
Kernel modules: mei_me
00:17.0 SATA controller: Intel Corporation Sunrise Point-H SATA Controller [AHCI mode] (rev 31) (prog-if 01 [AHCI 1.0])
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 126
Memory at ef330000 (32-bit, non-prefetchable)
Memory at ef336000 (32-bit, non-prefetchable)
I/O ports at f090
I/O ports at f080
I/O ports at f060
Memory at ef335000 (32-bit, non-prefetchable)
Capabilities:
Kernel driver in use: ahci
00:1c.0 PCI bridge: Intel Corporation Sunrise Point-H PCI Express Root Port #1 (rev f1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 123
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: None
Memory behind bridge: None
Prefetchable memory behind bridge: None
Capabilities:
00:1c.2 PCI bridge: Intel Corporation Sunrise Point-H PCI Express Root Port #3 (rev f1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 124
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
Memory behind bridge: ef200000-ef2fffff
Capabilities:
00:1c.3 PCI bridge: Intel Corporation Sunrise Point-H PCI Express Root Port #4 (rev f1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 125
Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
I/O behind bridge: 0000d000-0000dfff
Memory behind bridge: ef100000-ef1fffff
Capabilities:
00:1e.0 Signal processing controller: Intel Corporation Sunrise Point-H Serial IO UART #0 (rev 31)
Flags: bus master, fast devsel, latency 0, IRQ 20
Memory at ef334000 (64-bit, non-prefetchable)
Capabilities:
00:1e.2 Signal processing controller: Intel Corporation Sunrise Point-H Serial IO SPI #0 (rev 31)
Flags: bus master, fast devsel, latency 0, IRQ 22
Memory at ef333000 (64-bit, non-prefetchable)
Capabilities:
00:1f.0 ISA bridge: Intel Corporation Sunrise Point-H LPC Controller (rev 31)
00:1f.2 Memory controller: Intel Corporation Sunrise Point-H PMC (rev 31)
Flags: fast devsel
Memory at ef32c000 (32-bit, non-prefetchable) [disabled]
00:1f.3 Audio device: Intel Corporation CM238 HD Audio Controller (rev 31)
Flags: bus master, fast devsel, latency 32, IRQ 131
Memory at ef328000 (64-bit, non-prefetchable)
Memory at ef300000 (64-bit, non-prefetchable)
Capabilities:
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
00:1f.4 SMBus: Intel Corporation Sunrise Point-H SMBus (rev 31)
Flags: medium devsel, IRQ 16
Memory at ef332000 (64-bit, non-prefetchable)
I/O ports at f040
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
01:00.0 3D controller: NVIDIA Corporation GP107M [GeForce GTX 1050 Mobile] (rev a1)
Memory at ee000000 (32-bit, non-prefetchable)
Memory at d0000000 (64-bit, prefetchable)
Memory at e0000000 (64-bit, prefetchable)
I/O ports at e000 [disabled]
Expansion ROM at ef000000 [disabled]
Capabilities:
Kernel modules: nouveau
03:00.0 Network controller: Intel Corporation Wireless 8265 / 8275 (rev 78)
Subsystem: Intel Corporation Dual Band Wireless-AC 8265
Flags: bus master, fast devsel, latency 0, IRQ 130
Memory at ef200000 (64-bit, non-prefetchable)
Capabilities:
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
04:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
Subsystem: ASUSTeK Computer Inc. Device 200f
Flags: bus master, fast devsel, latency 0, IRQ 128
I/O ports at d000
Memory at ef104000 (64-bit, non-prefetchable)
Memory at ef100000 (64-bit, non-prefetchable)
Capabilities:
Kernel driver in use: r8169
Kernel modules: r8169
It’s indeed an Optimus system with an Intel Skylake. The driver (i915) is available but not loaded, probably due to missing firmware files. Please post the output of
rpm -ql linux-firmware | fgrep i915
if it complains about linux-firmware not being installed, install it, reboot and post the output of
lspci -v -s00:02.0
generix,
it looks like rpm is already installed:
/usr/lib/firmware/i915
/usr/lib/firmware/i915/bxt_dmc_ver1.bin
/usr/lib/firmware/i915/bxt_dmc_ver1_07.bin
/usr/lib/firmware/i915/bxt_guc_ver8_7.bin
/usr/lib/firmware/i915/bxt_huc_ver01_07_1398.bin
/usr/lib/firmware/i915/kbl_dmc_ver1.bin
/usr/lib/firmware/i915/kbl_dmc_ver1_01.bin
/usr/lib/firmware/i915/kbl_guc_ver9_14.bin
/usr/lib/firmware/i915/kbl_huc_ver02_00_1810.bin
/usr/lib/firmware/i915/skl_dmc_ver1.bin
/usr/lib/firmware/i915/skl_dmc_ver1_23.bin
/usr/lib/firmware/i915/skl_dmc_ver1_26.bin
/usr/lib/firmware/i915/skl_guc_ver1.bin
/usr/lib/firmware/i915/skl_guc_ver4.bin
/usr/lib/firmware/i915/skl_guc_ver6.bin
/usr/lib/firmware/i915/skl_guc_ver6_1.bin
/usr/lib/firmware/i915/skl_huc_ver01_07_1398.bin
/usr/share/licenses/linux-firmware/LICENSE.i915
while
lspci -v -s00:02.0 says:
I/O ports at f000
Capabilities: [40] Vendor Specific Information: Len=0c <?>
Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
Capabilities: [ac] MSI: Enable- Count=1/1 Maskable- 64bit-
Capabilities: [d0] Power Management version 2
Capabilities: [100] Process Address Space ID (PASID)
Capabilities: [200] Address Translation Service (ATS)
Capabilities: [300] Page Request Interface (PRI)
thank you :)
if it might me of interest:
lsmod | grep 915
snd_hda_codec_hdmi 49152 1
i915 1798144 0
i2c_algo_bit 16384 2 nouveau,i915
drm_kms_helper 159744 2 nouveau,i915
drm 352256 4 nouveau,i915,ttm,drm_kms_helper
video 40960 3 asus_wmi,nouveau,i915
So it seems everything is in place but the lspci command should also have the line
Kernel driver in use: i915
Please run
sudo dmesg >dmesg.txt
and attach that together with the file /var/log/Xorg.0.log to your post.
ok, attached.
Xorg.0.log (23.2 KB)
dmesg.txt (80.9 KB)
The kernel is not even trying to load the i915 driver. Please check if it is blacklisted, post the output of:
grep i915 /etc/modprobe.d/*
grep i915 /etc/modprobe.d/* gives empty answer.
Meh. Just saw that you have ‘nomodeset’ as kernel parameter. Remove that.
