Good afternoon,
I thank you please help me with a problem that I have with my Kali Linux virtual machine, although I install the necessary packages for the operation and recognition of the video card tells me that it does not find it, I appreciate your help.
Output:
root@xxx:~# apt install -y ocl-icd-libopencl1 nvidia-driver nvidia-cuda-toolkit
Reading package lists… Done
Building dependency tree
Reading state information… Done
ocl-icd-libopencl1 is already the newest version (2.2.12-2).
nvidia-cuda-toolkit is already the newest version (10.1.105-3).
nvidia-driver is already the newest version (418.88-1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
root@xxx:~# nvidia-smi
NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
Thanks for responding, the Hosted Hypervisor is “VMware: Workstation”, when I run an lspci, nothing on the card appears. And excuse me but I don’t understand the third point.
Thank you very much I will try, one more concern, my laptop has Windows 10 and VMWare installed and in the VMWare there is Linux, so I look for any of the ones you suggest for Windows and virtualize the correct Linux?
No client version will work. Only Windows Server 2016 and up. An in case you don’t know, You need two graphics cards for this to work at all, one for the host and one to pass through to the guest.
