Hey,
I know that this I a well know issue and that there are a lot of topics about this problem already.
My System:
GTX 760
Ubuntu 18.04
Current Driver: 440.5
Tested Drivers: 390, 415, 430, 440
My problem is that since I installed the Nvidia driver on my system the GPU continuously ramps up the fans (0rpm-~2500rpm).
Before that, there were no problems with the fans and there are no problems in bios, so I think it’s not a hardware issue.
Furthermore, when I run some benchmarks to push the GPU temperature to 70+C and then let it cool down, it cools down normally and stays quiet (~1400rpm) for about 20 mins.
What I have tried so far:
changing the drivers (390, 415, 430, 440)
=> no changes -
set the Coolbit to 4, 12 or 28
=> enables the manual fan control option, but the GPU ignores any fixed value.
=> could not figure out what 12 or 28 are doing but found it in some solutions -
nvidia-settings -a ‘[gpu:0]/GPUFanControlState=1’ -a ‘[fan:0]/GPUTargetFanSpeed=99’
=> no changes -
install nvclock
=> cant locate the NVClock package, I guess it’s deprecated -
install lm-sensors (fan-control)
=> sensors: shows the temperatures but no pwm/fanspeed
=> fan control: can’t change the fan speed (no pwm sensor) -
reboot the system
Screenshots / Logs
:~$ sensors
coretemp-isa-0000
Adapter: ISA adapter
Package id 0: +35.0°C (high = +80.0°C, crit = +100.0°C)
Core 0: +33.0°C (high = +80.0°C, crit = +100.0°C)
Core 1: +33.0°C (high = +80.0°C, crit = +100.0°C)
Core 2: +33.0°C (high = +80.0°C, crit = +100.0°C)
Core 3: +29.0°C (high = +80.0°C, crit = +100.0°C)
~$ nvidia-smi
Wed Oct 30 13:23:02 2019
| NVIDIA-SMI 440.26 Driver Version: 440.26 CUDA Version: 10.2 |
| 0 GeForce GTX 760 Off | 00000000:01:00.0 N/A | N/A |
| 48% 40C P0 N/A / N/A | 223MiB / 4034MiB | N/A Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 Not Supported |
$ sudo nvidia-xconfig -t
Using X configuration file: "/etc/X11/xorg.conf".
ServerLayout "Layout0"
|--> Screen "Screen0"
| |--> Monitor "Monitor0"
| | |--> VendorName "Unknown"
| | |--> ModelName "Unknown"
| | |--> HorizSync
| | |--> VertRefresh
| | |--> Option "DPMS"
| |--> Device "Device0"
| | |--> Driver "nvidia"
| | |--> VendorName "NVIDIA Corporation"
| |--> Option "Coolbits" "4"
| |--> DefaultColorDepth 24
Driver GUI
https://imgur.com/a/qzzySdv
I try now since 3 days to solve this problem and i hope someone has new idea how i could fix it.
