Hello there,
I am trying to run this below pipeline , This GStreamer pipeline is designed to read an H.264-encoded video file, decode it using NVIDIA hardware acceleration, limit the frame rate to 10 FPS, resize and convert the video to BGR format, and finally deliver frames to an OpenCV application via appsink :
gst_pipeline=(
f"filesrc location={path} ! "
f"qtdemux ! "
f"h264parse ! "
f"nvv4l2decoder ! "
f"videorate drop-only=true max-rate=10 ! "
f"video/x-raw framerate=10/1 ! "
f"nvvidconv ! "
f"video/x-raw,width=956,height=540,format=BGRx ! "
f"videoconvert ! "
f"video/x-raw,format=BGR ! "
f"appsink drop=1 sync=false !"
But it is giving the below error :
[ WARN:0@0.687] global cap_gstreamer.cpp:2839 handleMessage OpenCV | Gstreamer warning: Embedded video playback halted; module qtdemux0 reported: Internal data stream error.
If anyone can provide a solution to this please help. I am really greatfull to everyone.
