Harnessing the NVIDIA Ada Architecture for Frame-Rate Up-Conversion in the NVIDIA Optical Flow SDK
Originally published at: https://developer.nvidia.com/blog/harnessing-the-nvidia-ada-architecture-for-frame-rate-up-conversion-in-the-nvidia-optical-flow-sdk/
The NVIDIA Optical Flow SDK 4.0 is now available, enabling you to fully harness the new NVIDIA Optical Flow Accelerator on the NVIDIA Ada architecture with NvOFFRUC. Optical flow on the NVIDIA Ada Lovelace architecture Starting from the NVIDIA Turing architecture, NVIDIA GPUs have dedicated hardware for optical flow computation between a pair of frames.…
