We have our own carrier board with 4 USB C ports. Our controller chip is a USB5806CT. Our goal to do either DP or HDMI through our USB port but we would like to investigate what kind of current support may be available in Jet Pack and we would appreciate any other pointers you may have that we can investigate. Our USB Hub controller does support USB Alternate Mode which is what is needed for DisplayPort capability over USB-C. If know of any other COTS USB drivers available that we may be able to port that would helpful too.
DaneLLL
3
By default we don’t support HDMI/DP through USB on Orin series. Would see if 3rdparty has solution for the user-case and provide suggestion.
Related topics
| Jetson Orin NX HDMI and DP Question | 7 | 346 | November 7, 2025 | |
| Alternate Mode for USB Type-C Jetson Orin AGX | 3 | 433 | June 24, 2025 | |
| Display Port over USB 3.2 on Jetson Orin NX SOM | 1 | 872 | April 7, 2023 | |
| [ISSUE][USB-C][Display Port] USB-C DP support on Custom carrier board | 5 | 1087 | June 24, 2024 | |
| How to use usb 3.0 port as a DP or HDMI or Ethernet on jetson orin nano? | 3 | 521 | July 9, 2024 | |
| USB Type-C Display Output Support on Custom Carrier Board – Jetson Orin Nano | 2 | 102 | June 19, 2026 | |
| VGA to usb C | 1 | 580 | August 11, 2023 | |
| Display options other than DisplayPort | 2 | 835 | July 26, 2022 | |
| Devkit USB C flashing port specs | 3 | 419 | February 3, 2024 | |
| HDMI and USB HUB JETSON Orin NX | 11 | 212 | April 21, 2026 |
