HI Im Sorry to interrupt you ,when we want to develop a project with jetson orin nano, we need more display or Ethernet port, so we want to know about that How to use usb 3.0 port as a DP or HDMI or Ethernet on jetson orin nano? That means usb3.0 as one port, we can transfer Ethernet DP or HDMI media by use of USB 3.0?
looking for reply!
There is no support for this. Jetson does not support to output display from USB port.
thanks a lot for your reply , any other orin series can support usb3.0 to transfer DP or HDMI information?
No. The GPU is integrated directly to the memory controller (an iGPU), whereas the drivers which support this are for discrete PCIe GPUs (dGPU). So far there are no Jetsons which use a GPU on the PCIe bus. Maybe one day the iGPU driver and dGPU driver will not conflict, but currently that is not the case, so you couldn’t even add a dGPU.
