Display Port over USB 3.2 on Jetson Orin NX SOM
Does DP over USB 3.2 on Jetson Orin NX SOM require an external chip on the carrier board we’re designing to hold and drive the Jetson Orin NX module, like https://www.ti.com/lit/ds/sllsew2e/sllsew2e.pdf, or is the use of Display Port over USB 3.2 native and simply can be hooked up to a Type-C connector to plug into a USB Type-C to Display Port adapter or cable?
Hi, as you can see in the Orin NX Design Guide, DP over UB3.2 is not included. We only support the designs as listed in the DG.
