I have some questions about supporting USB function of Jetson Orin NX.
(1) Does Jetson Orin NX and Nano support Flip detection and CC control of USB Type-C?
(2) Does Jetson Orin NX and Nano support DRP(Dual Role Power) and DRD(Dual Role Data) of USB Type-C?
(3) Does Jetson Orin NX and Nano support Alternate mode of USB Type-C?
What you mentioned are features of PD controller/switch. Orin NX module does not contain that. It needs to add external PD controller / switch in your custom design.
Thank you for your reply.
I have other question.
About Type-C,
When I connect USB SS 2port of Orin NX to Type-C(TX1/RX1 and TX2/RX2), Can Orin NX swap lanes? software?
In this case, Do I need no external MUX?
No, swap is not supported, a switch is needed. For Orin NX, it is just a standard USBSS port, the external devices are necessary for type C design.
Thank you for your cooperation.
I have other questions.
(1)Does Jetson Orin SoM module itself have signal Integrity to satisfy USB compliance?
(2)Does Jetson Orin NX and Nano support USB3.2 Gen2×2(20Gbps)?
(3)If USB3.2[Port#0] and USB3.2[Port#2] of Orin NX is connected to TX1/RX1 and TX2/RX2 of Type-C, Can USB communication by either port if USB device connect to upside-up or upside-down? Please see as below.
Orin NX module, Type-C connector , Action
USB3.2(Port#0) <-------> TX1/RX1 of Type-C ← Connect upside-up Type-C cable
USB3.2(Port#2) <-------> TX2/RX2 of Type-C ← Connect upside-down Type-C cable
Please read the Orin NX datasheet and Design Guide in DLC first.
- Yes.
- There are two hubs internal for USB 3.2, each with 10 Gbps bandwidth. One hub is for Ports 0/1 and the other is for port 2.
- No.
Hi, Thank you for your support.
Does Jetson Orin NX and Nano support USB3.2 Gen1×2(10Gbps)?
I could not find this feature on the datasheet(Jetson_Orin_NX_DS-10712-001_v0.5.pdf)
No, only x1 is supported.
I understood it.
