How to configure or enable Display port from USB to DP display
I want to display HDMI and DP on the monitor, we develop a carrier board with DP and HDMI interface, hardware connection is HDMI from DP1 block and DP from DP0 block .
after assembly the Jetson orin nano board into the carrier board, HDMI is working, but DP connector no display, I found Jetson Orin nano board configure DP0 as USB output, How to configure it as a DP output.
Our purpose is to achieve a dual display on carrier board.
Thanks in advance
The real problem that needs to get clarified first is are you using Orin nano or Jetson nano???
They are totally different platforms and you are filing a topic on Jetson nano forum…
Thank your enquiry. it is Jetson nano.
Then why are you telling Orin Nano board???
這是Jetson Nano的話你為什麼要提起Orin Nano??
jetson nano.pdf (670.1 KB)
Sorry, I am not sure it is Jetson orin nano or jetson nano, and upload the datasheet. the title is “NVIDIA Jetson Orin Nano Series
Ampere GPU + ARM Cortex-A78AE CPU + LPDDR5”
Orin Nano只支援一個display head. 沒有辦法出HDMI+ DP
也沒有支援USB ->DP output.
這東西也不是Jetson nano. Datasheet已經寫得很清楚了 請搞清楚自己在使用哪個平台
這個forum也不是Orin Nano用的
另外這個連結才是Jetson Orin Nano - NVIDIA Developer Forums
Thank you. 非常感谢!我明白了
