插入hdmi后启动载板无显示,重新插拔hdmi后显示正常。
您好,
现在的问题是这样:插入HDMI后,启动载板,显示器会显示nvidia logo界面,到了登录界面后,显示器黑屏,但没有提示"无信号输入"。此时重新插拔下hdmi,显示器正常显示,可以看到登录界面啦!
想知道,为什么需要重新插拔下才可以正常显示?怎么可以解决这个问题?
I assume this is for Jetson instead of DRIVE. You should create your topic under an appropriate Jetson forums under Jetson & Embedded Systems - NVIDIA Developer Forums.
Have been changed
Are yo using devkit or with custom board?
Which JetPack SW you’re using?
Duplicated with After the hdmi is inserted, no display is displayed on the startup carrier board. After the hdmi is hot-swapped, the display is normal - Jetson & Embedded Systems / Jetson AGX Orin - NVIDIA Developer Forums
