HDMI HPD issue for L4T r36.3
Our device based on ORIN has an issue with HDMI hot plug on JP6.0GA.
If the HDMI display is not connected before powering up the device, there’s no display output after it powers up. However, if the HDMI display is connected before powering up, the login screen appears once power-up is completed.
We found a similar topic on JP6.0DP previously:
Has this issue been resolved on JP6.0GA?
Yes, such problem has been fixed in GA.
If you still have hotplug issue on your side, then it is something else. Probably some missing configuration.
Hi WayneWWW,
Could you help to check if the configurations below are right, or what else is missing?
  1. bootloader/tegra234-firewall-config-base.dtsi
        reg@322 { /* GPIO_CTL, GPIO_M_SCR_00_0 */
            exclusion-info = <2>;
            value = <0x38009696>;
  1. bootloader/generic/BCT/tegra234-mb1-bct-pinmux-p3701-0000-a04.dtsi
                        dp_aux_ch0_hpd_pm0 {
                                nvidia,pins = "dp_aux_ch0_hpd_pm0";
                                nvidia,function = "rsvd1";
                                nvidia,pull = <TEGRA_PIN_PULL_NONE>;
                                nvidia,tristate = <TEGRA_PIN_ENABLE>;
                                nvidia,enable-input = <TEGRA_PIN_ENABLE>;
                                nvidia,io-high-voltage = <TEGRA_PIN_DISABLE>;
                                nvidia,lpdr = <TEGRA_PIN_DISABLE>;
  1. tegra234-p3737-0000+p3701-xxxx-nv-common.dtsi
        display@13800000 {
                os_gpio_hotplug_a = <&gpio TEGRA234_MAIN_GPIO(M, 0) GPIO_ACTIVE_HIGH>;
                status = "okay";
This is not needed.
Actually you could just refer to p3509 config.
Got it. Thanks a lot!
