Hardware:
Orin nano module P3767-0003(with 256GB nvme) + customboard.
Custom borad status:
- Modified form Orin nano dev kit, but changed DP to HDMI.
- No EEPROM on it.
Jetpack:
5.1.3
My target:
Enable the HDMI output on custom borad.
Method:
I copied p3768-0000+p3767-0000.conf, named it p3768-0000+p3767-0000-zhou.conf, and modified two places:
-PINMUX_CONFIG="tegra234-mb1-bct-pinmux-p3767-dp-a03.dtsi"; -PMC_CONFIG="tegra234-mb1-bct-padvoltage-p3767-dp-a03.dtsi"; +PINMUX_CONFIG="tegra234-mb1-bct-pinmux-p3767-hdmi-a03.dtsi"; +PMC_CONFIG="tegra234-mb1-bct-padvoltage-p3767-hdmi-a03.dtsi"; -
Modify ./bootloader/t186ref/BCT/tegra234-mb2-bct-misc-p3767-0000.dts:
cvb_eeprom_read_size = <0x0>; -
Modify ./bootloader/t186ref/BCT/tegra234-mb2-bct-scr-p3767-0000.dts:
+reg@322 { /* GPIO_M_SCR_00_0 */ + exclusion-info = <2>; + value = <0x38009696>; + }; -
Download kernel, then modify ./source/public/hardware/nvidia/platform/t23x/p3768/kernel-dts/tegra234-p3767-0000-p3768-0000-a0.dts.
-#include "tegra234-dcb-p3767-0000-dp.dtsi" +#include "tegra234-dcb-p3767-0000-hdmi.dtsi" -
Then build the kernel and apply new image\dtb according to Kernel customization.
Sucessed flash with command:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml" --showlogs --network usb0 p3768-0000+p3767-0000-zhou internal
host_log.txt (317.7 KB)
Issues:
Sadly no output on hdmi at all…
1.xrandr can query HDMI device, but when HDMI cable is plugged in or not, it aways shows disconnected.
xrandr --query -display :0.0
2.Tips for checking HPD is working, when HDMI cable is plugged in it shows ‘1’.
echo 424 > /sys/class/gpio/export
cat /sys/class/gpio/PM.00/value
So please help me.
By the way:
- I can’t use p3509-a02+p3767-0000.conf for flashing, because my custom board nvme doesn’t fit for it.
