I am trying to create a “headless server” using the TX2. I installed Jetpack 3.2.1 without vision, Cuda or other libraries and samples. The install still contains “desktop” environment complete with libreoffice, chromium etc. Removed the desktop applications but when I try to remove X modules, a lot of other systems break including the network.
Can you someone point me to any notes or documentation for minimal server installation for the TX2? I can always install the modules I need.
I may not have explained clearly. The TX2 will be used in the field connected to a cell network for some autonomous data collection and processing (occasional remote access). Having X/Desktop tools/applications is not necessary (example thunderbird or libreoffice etc.) I can always ssh into the system for remote access. Access is not the issue.
I am trying to remove X tools and make TX2 a remote, headless system in other words a server platform. I did the following… but it breaks a lot of regular packages including network operations. Wondering if someone has done something similar and managed to get a minimal, non-desktop installation working.
update
sudo apt-get update
install the ‘tasksel’ package so we can remove the desktop image
X11 is usually misunderstood. X does not provide any desktop or end user applications by itself, it simply provides GPU access (or framebuffer access) in a standardized way. In the past nobody used a GPU for anything but video, and naming tends to fool people into thinking X is desktop display software and not an ABI talking to a framebuffer or GPU. The NVIDIA driver is bound to the ABI of the X server, and much of what CUDA accesses is via the X ABI even when there is no desktop. Think of a virtual server as a headless stub to the GPU…though it can be a proxy where a remote application might talk to it. Should it happen that the virtual desktop runs something within it which is a GUI it works and can be viewed by remote software…should it not be a GUI and still provide GPU access to CUDA, this also works.
The reason why an end user of CUDA or video must be in group “video” (“grep video /etc/group”) even when no video is involved is because this is really “the group for GPU access”.
What you really want to get rid of is the login manager and window manager, along with all applications linked to those as end user software.
I remember a while back someone had posted some steps for some sort of absolute removal of X (perhaps @WayneWWW?), but unfortunately I don’t remember which thread that was in.
sudo systemctl set-default multi-user.target
sudo system systemctl mask lightdm.service
reboot
you will now boot in text mode without a display manager.
I struggled with creating a minimal system for a while but gave up on the effort because it became a big headache and needed to be redone and tested each time NVidia came out with a new release. Simply disabling the display manager and leaving all the packages installed accomplished the objective of booting to a minimal system.
