I was following this tutorial: https://www.youtube.com/watch?v=cxZ2xs1s77Q
But when I run as described at time 4:44 I get a dependency error.
$ ./app/omni.micro.sh
Loading user config located at: '/home/manifold6/.local/share/ov/data/Kit/omni.micro/0.1/user.config.json'
[Info] [carb] Logging to file: /home/manifold6/.nvidia-omniverse/logs/Kit/omni.micro/0.1/kit_20231128_152846.log
[0.115s] Failed to solve some dependencies locally, syncing with extension registry...
[0.117s] [ext: omni.usd.config-1.0.0] startup
[0.129s] [ext: omni.usd.libs-1.0.0] startup
[0.239s] [ext: omni.kit.async_engine-0.0.0] startup
[0.240s] [ext: omni.assets.plugins-0.0.0] startup
[0.242s] [ext: omni.client-0.1.1] startup
[0.249s] [ext: omni.kit.registry.nucleus-0.0.0] startup
2023-11-28 23:28:46 [328ms] [Warning] [omni.client.plugin] Tick: authentication: Could not resolve host name "kit-extensions.ov.nvidia.com"
2023-11-28 23:28:46 [406ms] [Warning] [omni.client.plugin] Tick: authentication: Could not resolve host name "kit-extensions.ov.nvidia.com"
2023-11-28 23:28:46 [445ms] [Warning] [omni.client.plugin] Tick: authentication: Could not resolve host name "kit-extensions.ov.nvidia.com"
2023-11-28 23:28:46 [509ms] [Error] [omni.ext.plugin] Failed to resolve extension dependencies. Failure hints:
[omni.micro-0.1.0] dependency: (name: 'omni.services.transport.server.http', tag: '', version: '1.2.1', exact: 0, optional: 0) can't be satisfied. Available versions:
(none found)
2023-11-28 23:28:46 [509ms] [Error] [omni.kit.app.plugin] Exiting app because of dependency solver failure...
[0.521s] [ext: omni.kit.registry.nucleus-0.0.0] shutdown
[0.535s] [ext: omni.client-0.1.1] shutdown
2023-11-28 23:28:46 [537ms] [Warning] [carb] [Plugin: carb.datasource-omniclient.plugin] Module /home/manifold6/.local/share/ov/pkg/deps/d63ea876e0b68c9bd49a17dcbc178280/extscore/omni.client/bin/deps/libcarb.datasource-omniclient.plugin.so remained loaded after unload request
2023-11-28 23:28:46 [539ms] [Warning] [carb] [Plugin: carb.datasource-omniclient.plugin] Module /home/manifold6/.local/share/ov/pkg/deps/d63ea876e0b68c9bd49a17dcbc178280/extscore/omni.client/bin/deps/libcarb.datasource-omniclient.plugin.so remained loaded after unload request
2023-11-28 23:28:46 [539ms] [Warning] [carb] unloadPlugin: Failed to find a plugin at: /home/manifold6/.local/share/ov/pkg/deps/d63ea876e0b68c9bd49a17dcbc178280/extscore/omni.client/bin/deps/libcarb.datasource-omniclient.plugin.so.
[0.551s] [ext: omni.assets.plugins-0.0.0] shutdown
[0.551s] [ext: omni.kit.async_engine-0.0.0] shutdown
[0.565s] [ext: omni.usd.libs-1.0.0] shutdown
[0.579s] [ext: omni.usd.config-1.0.0] shutdown
Not sure why this is the case because when I look in the extscache the dependency is there:
ls extscache | grep omni.services.transport.server.http
omni.services.transport.server.http-1.2.1
I am on Ubuntu-22.04.
