Hello AI and Jetpack 6.2
Hello – I have a jetson orin nano with jetpack 6.2.1, L4T 36.4.7, CUDA 12.6.68. I have tried to install jetson-inference from sources. However I can not seem to be able to run any of the imagenet programs. Looks like there is a breakdown regarding Caffe models that are not supported in the new Jetpack. Can any one provide any suggestions on how to go about this? I could only get videoSource, videoOutput, resize and convert color functions to work from jetson_utils. I did install a docker container as well. I made more progress with that but even that had issues with crashses after showing image and detection. Thnx.
Hi Botz,
I have moved your post to the Jetpack section for better visibility. Thanks for posting on the forums!
Best,
AHarpster
jetson-inference is deprecated.
Please set up the device with JetPack 6.0 if you need to run the example.
