Hi, i’m currently using Bumbleblee on my Dell XPS L702X with Ubuntu 13.04 x64
I’m kinda new to Linux and i took time to make Bumblebee work on my GT555M because of Optimus.
I would like to know how to properly uninstall Bumblebee and all these things, and then install and setup the Nvidia proprietary drivers (Lastest is 325.15).
Also (and that may be related or not) i have noticied that after installing Ubuntu i’m experiencing some kind of “freez” (The screen goes full grey or any other color then sometimes turn black), that’s only happening when i try to run games (on Windows my GPU is at ~90°C after 1h of gaming and 70°C on idle), i also hear that the fans aren’t running as fast as on windows when i play.
(I can’t get temperatue info on Linux lm-sensors only shows the 8 processors charge and 2 virtual Temp)
nvidia-smi on Linux should display GPU temperature.
Changing fan speeds is going to be either a pain or impossible on Optimus w/ Bumblebee, you’d have to add the coolbits flag in your bumblebee xorg.conf, and even then I don’t remember if it actually populates correctly to be able to change the values via nvidia-settings. I haven’t tried the native workaround, so I’m not sure you’re able to change it that way either.
I’m assuming you’re looking to run the latest driver natively with xrandr 1.4 and dump Bumblebee – Look around this forum, there have been various threads of user’s experiences and how-to’s… but it might not be terribly straightforward.
Ok, so i Uninstalled every graphic card related package (Bumblebee-nvidia, nvidia-current and nvidia-104 from memory)
Then i installed the lastest drivers (325.15) by doing:
'Ctrl + Alt + f2'
Logging
service lightdm stop
sh ./Downloads/NVIDIA-[...].run
Saying "yes" to everything
After reboot i’m having lot of troubles:
After booting the screen is stuck in 640*480
Error message after logging:
none of the selected modes were compatible with the possible modes:
Trying modes for CRTC 63
CRTC 63: trying mode 640x480@60Hz with output at 1920x1080@60Hz (pass 0)
CRTC 63: trying mode 640x480@60Hz with output at 1920x1080@60Hz (pass 1)
Trying modes for CRTC 64
CRTC 64: trying mode 640x480@60Hz with output at 1920x1080@60Hz (pass 0)
CRTC 64: trying mode 640x480@60Hz with output at 1920x1080@60Hz (pass 1)
When doing "nvidia-settings" message on the GUI:
You do not appear to be using the NVIDIA X driver. Please edit your X configuration file (just run `nvidia-xconfig` as root), and restart the X server.
NO UNITY, nothing showing up ... no menus, nothing ...
The screen resolution is fixed by removing xorg.conf (“rm /etc/X11/xorg.conf”)
But when i do an “nvidia-config” and reboot, it goes back to 640*480
When you mentioned you had Bumblebee installed, I assumed that you would have been running it with the NVIDIA drivers vs nouveau – if you were running with the latter, it doesn’t surprise me that you had issues.
With any system that has Optimus, you’re not going to be able to just install the newest drivers and having it work out of the box – it requires a specific setup,
In case you haven’t seen it yet, the thread on getting drivers to work natively that I was referencing is this one:
