I have been trying to install cuda on my linux mint laptop with a gtx 660 m card, but i am running into an issue.
I started with installing the nvidia drivers. Using nvidia-smi i get the following:
| NVIDIA-SMI 331.38 Driver Version: 331.38 |
| 0 GeForce GTX 660M Off | 0000:01:00.0 N/A | N/A |
| N/A 54C N/A N/A / N/A | 196MiB / 2047MiB | N/A Default |
| Compute processes: GPU Memory |
| GPU PID Process name Usage |
| 0 Not Supported |
| Therefore i assume that the drivers are installed correctly and in operation. |
When i then try to install cuda with ´sudo apt-get install cuda-6-0´ i get the following:
The following packages have unmet dependencies:
cuda-6-0 : Depends: cuda-drivers (>= 331.00) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Now i am a bit stuck since nvidia-smi tells me that the correct drivers are installed while apt-get disagrees. Any insight would be greatly appreciated.
